1994 XJ12 Throttle Position Sensor unavailable, alternatives ?
Last Roadster
Any ideas on alternatives or substitutions for the six lead TPS for 1994 XJ12 ? Your thoughts and suggestions would be greatly appreciated. Last Roadster
equiprx
Should be the same as the XJS 6.0.
Check the part numbers and get back to me.
I think I still have a couple in my spares bins.
Best to text me to six50-455-one,one,one 0.
Steve
T Question on 1994 XJ12 fuel pump Jaguar 3
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
G 1994 MX5 Miata Other Cars 6
M 1994 xj6 ride height Jaguar 1
6 1994 Mercedes ABS light Other Cars 0
bmurphy7369 1994 XJ6 XJ40 fuel pump replacement Jaguar 6
D 1994 xjs 6.0 $2 free delivery worldwide. Jaguar 4
R General question about 1994 XJS Jaguar 3
I 1994 vanden plas: brake job questions ?? tips ?? Jaguar 9
J 1994 XJ6 climate control problem Jaguar 0
J XJS 1994 model year Latest Jaguar 0
S 1994-96 xjs convertible Jaguar 0
P XJ12 Wiring diagrams Jaguar 1
P XJ12 Fuel pump relay 85 Jaguar 4
L 94 XJ12 Jaguar 1
D How much room in the XJ12[ 3] /XJ-S engine bays? Jaguar 0
Basil Check out V12_Jagman's XJ12! Jaguar 2
L XJ12 Horns Jaguar 2
E XJ12 Purchase advice Jaguar 4
B A Few Questions about my XJ12 Jaguar 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
catfood Throttle return mechanism on the BN1 Austin Healey 4
