TR4/4A TR4-Stromberg throttle shaft play
Steviemc
Oh wise ones, a question if I may?
I'm struggling to get my TR4a, fitted with Stromberg carbs, to idle smoothly. Also it stutters at low revs and when on a very light throttle...goes great above 2000rpm.
I noticed my throttle spindles have some play in them, not a huge amount but definitely noticeable. Is there a tolerance for play on these? I'm guessing air might be getting in and messing up the mix when the throttle valve is closed.
Any wisdom or top tips?
Sarastro
Ideally, the shafts should be a close, smooth, sliding fit. They always wear though, and it can be hard to say how much wear is acceptable. I've never seen a spec for this. A little air leakage probably doesn't affect the running, but it makes it very difficult to set up the mixture correctly.
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
J TR4/4A TR4 Stromberg Carb Question ? Triumph 12
SCguy TR4/4A TR4 Stromberg Carb. adjustment Triumph 12
Andy Blackley TR4/4A TR4 Stromberg Floats Triumph 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
