TR4/4A First startup of TR4
Twit
Member
I'm reassembling a 1961 TR4 CT2292.
Previous owner left me a rebuilt block that had never been started and sat dry - but in heated dry garage. I took off the cover and dosed it in oil and tranny fluid. It turned easily so I think I'm ok.
And by block I mean just the block. So I've now built it out and today it got a battery. So once I've verified circuits its going to be time to try and fire it up.
I have not done a fire up on one of these so I'm looking for some guidance. I'm obviously going to put some proper oil in it and then I figure to:
- put in some gas and hand pump it through with the gas line off to the carbs to allow flow through. I have an in-line filter there so once I see gas I close it in. then check for leaks.
- use the solenoid to roll the motor without spark. I figure I need to leave the line to oil gauge open to bleed out the air.
- once I have oil coming out then hook up the oil gauge and look for pressure. Check oil level.
- add coolant and oil to the carbs
- roll the car some more and look for leaks
- I installed distributor so I think its right but I'll regap the points.
- add spark and see if it fires.
Last motor I did the startup was my '69 Cougar and I seem to recall adding something to allow break-in for like 500 miles then changing oil. From what I've read it seems I should be looking to put pressure on the rings to get them to seat in the TR4 but no talk of additives. So some forays around the neighbourhood are called for. Then retorque the heads after 30 minutes of run time.
Is that about right?
thanks Dave
Sarastro
You don't need to bleed air out of the oil-pressure line. Any air bubbles will compress until they reach equilibrium at the oil's pressure.
You also don't need to purge the fuel line. The gas will get to the carbs even with bubbles in the line.
Set the carbs' jet adjustments to about 2 turns down from the leanest position, and static time the distributor to about 5 degrees, as described in the owner's manual.
I wouldn't turn the engine over more than necessary until you have oil pressure. Traditionally, we crank it without the plugs in place (so it turns over faster) and get the oil pressure up. Then replace the plugs, start it, and run it for 20 min or so at 2000 RPM to seat the rings. Yes, I'd change the oil after 500 miles or so--that was the factory recommendation, I think.
If it's been sitting a long time without being turned over occasionally, the rings may have been stuck to the cylinder walls and caused some damage. No way to know until you start it and look at the exhaust color. Good luck!
Hamish Racing
This is all good advice. Getting the oil pressure up by cranking and before firing is good. You can disconnect the coil wire and use the key and watch the oil gauge that way it won’t fire up or burn out the coil- like using the solenoid button but in comfort.
The 2000 rpm for 20mins is very important more for the cam and followers than the rings. It is these that have the hardest life.
good luck.
Madflyer
I am with all the above Oil pressure is key You oil gauge may peg 100 PSI if it does not there is a brass caped plug by the fuel pump Pressure relief that may stick open. Leave Rad cap off and look for steam when thermostat opens as temp goes up to say 160 deg. plus. You may not want any water pressure until retorque head. I run up at temp three times for 15 min looking for leaks should be safe keep FIRE EX close for gas leaks. Others may have more. Madflyer
Twit
Twit
Member
thanks for all the advise. I've read it over and over.
I am worried about gas leaks. I used 5/16 hose and it didn't seem tight enough but 1/4 just wouldn't go on. I've put clips on the hose piece under the car and I may just clip them all for the startup. And I will pick up a fire extinguisher and I'll probably pull it out into the driveway.
Still a couple weeks away I think. I diverted to put my spitfire back on the road.
I have now arranged to have the fellow that rebuilt the block (15 years ago) to come help me start it up. It was rolled periodically with some oil down the cylinders so I'm hoping its solid. It wasn't frozen when I got it.
PAUL161 T-Series Puff of blue smoke on startup MG 17
C TR2/3/3A Gears grinding on first startup..... Triumph 14
R First startup after decades dormant Austin Healey 12
J TR2/3/3A Torqueing heads after startup. Triumph 6
JPSmit New Oil Pump startup Spridgets 8
S TR2/3/3A initial startup of a motor Triumph 20
longbridgehealey startup checklist Spridgets 6
N First startup in almost 30 yrs, a no-go Austin Healey 19
PatGalvin TR2/3/3A TR3A Engine Startup Follies Triumph 23
R Initial startup after 22 years Austin Healey 22
Bruce_B Need help with oil pressure on startup of engine!! Spridgets 8
tosoutherncars Rattle on startup - 1500 Triumph 5
Bruce_B Best Oil for Startup of Rebuilt Engine - Recommend Spridgets 5
G Clanking noise is getting worse on startup..... Triumph 25
D TR6 TR6 startup Latest Triumph 1
D TR6 TR6 Startup Latest Triumph 2
MadRiver Blue smoke on startup? MG 8
B Ignition help - initial startup not going well Spridgets 5
drooartz Squealing brakes at startup in cold weather Other Cars 2
A startup trouble Triumph 4
hvacr first startup MG 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
