hvacr
More experience needed. I put all the new parts in my 1500 Midget engine and it runs great ...but I see no fuel filter and I have fuel starvation symptoms. That’s one problem. I also have some questions about the cooling water flow. The manual does not actually show much. The new radiator (brand new from Moss) has a small tube where there was a big tube. What do you call this system with the two tubes on each side of the bottom? Will it typically overheat during a long idle? I’m not sure the t’stat opened. But I can check that tomorrow.
