TR4/4A TR4 Body Number Plate Supplier
Rod-H
Bronze
Does someone have a supplier for a TR Body Number Plate? This is not the commission plate, near the wiper motor, but the one on the right hand side of the firewall that has a stamped number on it only.
I order one form Clark Spares (who I have used in the past) called and said the person who made the plates passed away and no one else knows how to do it.
Thanks in advance.
Rod
KVH
Sorry to respond off topic, but how do I explain to the local DMV Registration office why there are two tag numbers under the hood? I realize one is the commission and the other is for the body, but can you elaborate on why Moss and all other registry sites address solely the commission number on the wiper motor side?
Geo Hahn
I've never had the AZ MVD challenge the use of the commission number for registration. I think or assume that the separate and different tag for the body was just so Mulliners could keep track of their builds.
As for the registries, most production changes were implemented and documented using commission numbers so those are most useful when ordering parts or judging correctness.
Allen W
AZ DMV !@#$ Years ago I bought a new (1987) Dodge Shadow From AAFES, while serving in Germany, upon returning to states (AZ) & trying to register auto in AZ it seems their Computer system did not "recognize" the MFR serial # for a car sold overseas (export #). Someone did not program their system with all the correct possible veh. serial numbers. After much hassle I was finally able to register the Dodge. My parents bought a new "Wide Body" Ford motorhome from an AZ dealer & then was told by AZ DMV that it was illegal in AZ & couldn't be drove. Again, after much hassle involving dealership, MFR and DMV, it was determined to be LEGAL & was finally licensed. Now local DMV has removed all the chairs from waiting area forcing older or disabled people to stand for long waits. Used to get # and wait to be called to window.
Sarastro
One option is just to leave the body-number plate off. It has no legal significance and can cause confusion as to the VIN number.
I've occasionally heard of cars being registered under the body number instead of the (correct) commission number. Then, removing it would be a problem, but in the absence of such special cases, you don't really need it. Of course, keep the number in your records, just in case.
Rod-H
Rod-H
Bronze
Thanks for the info gentlemen, sorry to re-derail the subject, but does anyone know where I can purchase a body number plate ;)
Rod
Popeye
Bronze
Unfortunately I don’t think these are available anymore. All the suppliers show them as NLA. And the topic comes up in forums periodically - without resolution.
These are similar - but different: > Aluminum Tags Engraved Round End Rectangle | NapTags <
IMO a homemade tag might be the most “authentic”. Or get someone to laser-cut the metal, then stamp it yourself.
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
B TR4/4A Body tub differences - TR4/4A Triumph 8
TR6oldtimer TR4/4A TR4, parts car not body Triumph 6
J TR4/4A Triumph TR4 Body Restorer Chicago Area Triumph 3
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
K TR4/4A The TR3 body on the TR4...how did it work out? Triumph 5
Alan_Myers GT6 Free GT6 body shell, SF Bay Area. TR4 & TR6 Triumph 1
mondialo64 TR4/4A TR4 Body cutting oversize mags Ideas? Triumph 9
V TR4/4A tr3 body on a tr4 frame Triumph 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
