    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR4/4A The TR3 body on the TR4 frame?
karls59tr
Bronze
Wasn't there someone on this forum doing this conversion? Wonder how it turned out?Any pics advice on how to do it? Anyone remember if it was doable on the TR4A frame with the IRS or was the frame too wide at the back? Karl
Russ Austin
I also remember seeing pic's of the body on the frame and just needing finishing! Would love to see how it turned out!
Geo Hahn
There was someone, but of course they had to widen the TR3 body by welding an insert into panels, apron, bonnet, boot lid, etc.
Twosheds
Couldn't one just widen the wings, like the TR3 Beta? Seems like it would be much easier than widening the bonnet, etc.
Geo Hahn
Since the outriggers that mount to the body are longer (wider) on a TR4 wouldn't the whole body have to be a couple of inches wider?
Anyway, that is the method I recall seeing posted -- a strip 4" wide or so inserted into the length of the body.
K
karls59tr
Bronze
I think ther is a company in England that can supply the the wider fenders.There was one fellow that was widining the body 4' but I think there was another that just used the wider fenders.
gsalt57tr3
Somehow I think modifying the frame might be easier...
Fit the tr4 frame to the tr3 body?
MDCanaday
Since the tr4 frame is just a modified tr3 frame,if you were crazy enough , you could retro it pretty easily.The out-riggers are wider but easy to shorten,the frame has bolsters on the sides of the rails in front of the suspension.Plasma tourch time...There are several other minor things but they can be left alone, since they dont bother much.
I guess its better to not ask why this is a question...
MD(mad dog)
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
K TR4/4A The TR3 body on the TR4...how did it work out? Triumph 5
V TR4/4A tr3 body on a tr4 frame Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
BlueMax TR2/3/3A No Body Filler On This TR3 Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
J TR2/3/3A TR3 Guy '59 project Basic body work finished Triumph 5
K TR2/3/3A TR3 body fitting question.... Triumph 3
O TR2/3/3A TR3 Body Mounting Hardware Triumph 1
J TR2/3/3A TR3 splash guards... body color or black? Triumph 15
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
J TR2/3/3A TR3 windshield angle and body shims Triumph 11
M TR2/3/3A TR3 to body shop Triumph 8
mgedit TR2/3/3A TR3 Body Mounts Triumph 2
mgedit TR2/3/3A Body back on Frame [56 TR3] Triumph 11
T TR2/3/3A A couple TR3 body questions Triumph 4
T TR2/3/3A TR3 replacement body panels Triumph 14
CJD TR2/3/3A TR3 Body gaps Triumph 20
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
B TR2/3/3A 57 TR3 TS19009 body plates Triumph 4
H TR2/3/3A tr3- body guru's - HELP Triumph 28
G TR2/3/3A TR3 Body Removal Triumph 4
Tr3aguy TR2/3/3A Help....Time for the body to come off [TR3] Triumph 7
T TR2/3/3A TR3 fitting body to chassis Triumph 7
M TR2/3/3A TR3 body back on chassis for trial fit Triumph 10
luke44 TR2/3/3A TR3 Body Stripping Bare QuikStrip Allentown Triumph 25
Tr3aguy TR2/3/3A Body removal TR3 Triumph 2
luke44 TR2/3/3A TR3 rotisserie or body buck questions Triumph 24
O TR2/3/3A TR3 Body Panel Fitting Triumph 4
B TR2/3/3A Pulling TR3 body off question Thanks Triumph 15
S TR2/3/3A body tub tr3 Triumph 5
T TR2/3/3A TR3 crossbar - body color or always black? Triumph 4
mrv8q TR2/3/3A TR3 Body part needed Triumph 4
GBRandy TR2/3/3A TR3 Body tags & Eng S/N Triumph 22
M TR2/3/3A TR3 Body Shell Restoration Progress Triumph 11
M TR2/3/3A TR3 body question seam or no seam Triumph 7
M TR2/3/3A TR3 Rear Body Damage Triumph 9
GBRandy TR2/3/3A TR3 Body ID Numbers Triumph 4
martx-5 TR2/3/3A TR3 Body Mounting Triumph 1
T TR2/3/3A weight of tr3 body? Triumph 15
Brooklands TR2/3/3A Here is an interesting Devin body for TR3 on eBay Triumph 1
S TR2/3/3A tr3 body tub color Triumph 8
H TR2/3/3A TR3 BODY NUMBERS Triumph 37
S TR2/3/3A tr3 body tub Triumph 3
Russ Austin TR2/3/3A Interesting TR3 Body Mods Triumph 16
