TR2/3/3A The "wide body" TR3?
karls59tr
Bronze
Does anybody have a link to the site where a fellow cut a TR3 down the middle and widened the car about 8" for his V8 project?
billspohn
Randy is a friend of mine and is a retired shop teacher with crazy good skills doing this sort of thing. Take a look at
> Randy Schultz's Triumph TR3 "Plus 4" Project, Part 1 < (there are 3 episodes).
On a drive we took - a Panther J72, my Jamaican MGA (V6 power) and Randy's TR
TomMull
Not that it has much to do with Randy's amazing car, but the TR2/3 is narrow. Mine is too narrow for my scissor lift. If my google search is correct, it is also 4 inches narrower (track measure) than the MGA and 5 inches narrower overall than the A40 Austin. Not surprisingly it's a good 2 feet narrower than a Lincoln Continental of the same vintage.
Tom
billspohn
If you hang around Randy's car for a little bit, it just looks right and original TR3s look anorexic.
He pretty much had to winden it as he wanted to use a TR6 frame with IRS and the front IRS mounting points would have been out in the air with a stock TR3 body. Cutting it down the middle and widening it took a lot of skill and if it had been me I'd probably have just used the original chassis amd grafted the new running gear in, but then I have never been a fan of the Triumph IRS rear suspension - very poorly selected spring rates and half shafts that are diabolical if you race one (most replace them with better shafts_.
K
karls59tr
Bronze
Randy did a very professional conversion and still retained the basic lines and style of the TR3. If you want to see how the a humble TR3 gets butchered go to this site: "Red , White and Boosted. They try to put a TR3 shell on a Mercedes chassis! Oh my eyes!
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
M TR4/4A Is there a world wide map of members available on this website? Triumph 9
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
Tinkerman TR2/3/3A Mounting the Wide Mouth Grill Triumph 5
Z 100 Wide Belt Generator Pulley Austin Healey 5
R wide band O2 sensor recommendations? Spridgets 10
aeronca65t Four Wide finish. Racing 3
R TR4/4A Tire options tr4a 60 spoke wheels 4.5 inch wide Triumph 43
M Posting is to wide Triumph 0
M Posting is to wide FORUM Navigation Questions 3
T 6 inch wide wire wheel Austin Healey 3
Jim_Newman e type pedal - and wide feet Jaguar 4
Schroeders T-Series Need pics of a TF on wide whites please MG 2
M 5 " wide wheels on Bugeyes Spridgets 6
G Small mouth on wide mouth TR ? ? Triumph 4
G Throttle stuck wide open on the way home tonight Spridgets 14
T How to run a business - Peter at World Wide! Triumph 5
bobh Posting Wide Pictures Triumph 14
M Throttle stuck wide open Austin Healey 4
John Moore Bugeye Tire Size and Wide White Walls Spridgets 14
davidk Drivers seat is too wide! Triumph 4
M What tires [tyres?] for a 4.5" wide 15" rim? Austin Healey 6
milemarker60 TR6 8 Inch Wide Wheels on a TR6??? Triumph 2
F TR2/3/3A TR3 Extra Wide WhiteWalls Triumph 3
D TR6 lost body shell Triumph 1
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
