TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims?
Kingcat
I’m installing Goodparts Trail arm kits on my frame. Somewhere in the instruction or I read on a post that to set the toe shims are needed between the mounts and frame. It was so long ago since disassembly I have no idea how many shims were there originally. Is this something I shouldn’t worry about now since it’ll be awhile before the suspension is fully loaded. Or should I put a couple in to fit up the TA’s Thanks
poolboy
If the toe (or wheel base) is too far off without the shims or the wrong number of shims you'll know it on your first drive.
Been there.
Tybalt
As poolboy says, you still need to shim to even out wheelbase and adjust rear toe. The significance of the adjustable bracket is that they let you adjust camber without all the exercises of figuring your baseline then juggling one, two or three notch brackets and whether or not they should be notches up or notches down to adjust rear camber. After that little exercise, you get to recheck rear camber and if it is not where it should, you get to disassemble, rejuggle everything and reassemble then recheck repeating as necessary until you get it where you want it. I talked a friend into getting a set for his TR250 before he took it in for an alignment. The folks at GT East knew what rear camber adjustment was like on these cars and went into it expecting the usual task ahead. Then they saw the adjustable trailing arm brackets and he said they just smiled and then asked why he didn't tell them he had those on the car. Everyone was happy.
The only thing I didn't like about that kit, and it seems the vast majority of kits out there regardless of source is the hardware. Richard uses SAE hardware which has somewhat restricted bolt grip length choices available and longer threaded sections. I replaced the supplied hardware with AN stuff so I could make sure that the threads would not be loaded in shear (bad juju there). The primary pivot bolts are an AN7 but I don't recall specifically which grip length dash number I used. I think it was -42 which is a 3 11/16" grip length but take a measurement on the movable block outer to outer face to confirm the grip length you need. The callout for the bolt you need if -42 is the correct grip length would be AN7-42A for an undrilled head and undrilled shank 7/16" bolt. Another thing is that you will probably need slightly longer bracket to frame bolts unless Richard is kitting them with longer bolts now to allow shim fitment compared to when I bought them many years ago. Those would be an AN6-xxA but I have no idea off hand what grip dash number other than it was in the -5x or low -6x range. It's been many years now and the memory has gotten a bit foggy on that level of detail.
And remember, you can always "adjust" grip lengths by going the next dash longer and stacking washers on the nut side (or on the bracket to frame bolts more so on the bolt head side) if need be to keep the threads from seeing shear loads. Good sources for AN hardware are Aircraft Spruce and Pegasus Racing.I find that I can buy AN stuff from Spruce and often from Pegasus for less than what I would pay at local hardware stores or local fastener houses. Once or twice a year I take a look at what I have on hand and place what amount to a stock order with Spruce as a result. Pegasus has a nice little explainer on AN fastener callouts here:
K
Kingcat
Thanks for the great info on the bolts. Not sure if my kit came with the longer bolts. Since the suspension won't be put under load for a good while should I put acouple of shims in just for mounting the TA's now. Thanks again. One of those long restoration stories 40 yrs in the making. Lot's of questions. Thanks
Tybalt
Probably not a bad idea to get things semi-dialed in if the suspension and hub are in place and the car is already up in the air but not really required at this point. You can at least get the wheelbase adjustment pretty close and depending on what kind of precision measuring instruments or if have them, toe plates, you can do a little in that area too. Just bear in mind anything you do now regarding rear toe will probably have to be readjusted somewhat once you start adjusting camber. They are interrelated to some degree so an adjustment to one means that you need to at least check the other. And make sure that you allow the suspension to "settle" by rolling the car back and forth a few times unless you are using some hubstands on a really nice smooth level surface that allow the suspension to settle as you lower the car.
mctriumph
Get some string. The roughing out of the rear suspension is a lot of fun. Find the center line of the frame, use it for a reference
for installing the shims. Bear in mind you are setting the THRUST alignment also . The wheel base and the tow need to be reasonably close
to drive it to the alignment shop .Just get in the ballpark ,Buy the beer when you get there!!
Mad dog
K
Kingcat
This is great advice that will give me some direction to use now. These are things I wouldn't have thought of at this point in reassembly. Thanks
K
Kingcat
Thanks for the great advice. I'll keep the info in mind as I set things up.
K
Kingcat
Mad dog
Driving to the alignment will call for a celebration.
mctriumph
Yes kingcat, it will be great but dont under estimate the thrill of seeing FOUR wheels on the ground
holding up a well done chassis . Then the motor can be set in and soon the body can be affixed!!
Mad dog
K TR6 Goodparts Nissan differential swap Triumph 3
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
Brosky GoodParts CV Axle Assemblies Triumph 6
SCguy Goodparts rear nylatron bushings... reuseable? Triumph 2
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
T Goodparts trailing arm bracket install question... Triumph 4
E Goodparts GP2 And Lifters Triumph 9
J Revington coilovers with goodparts swaybar Triumph 7
poolboy Goodparts Oil Seperator Triumph 9
tomshobby goodparts valve springs Triumph 21
LastDeadLast CV Axles/hubs from Goodparts Triumph 31
hondo402000 Goodparts Triple Carb manifold for sale Triumph 0
Strapping_Lad New Top Gear Episode! Trail rally with spridget Spridgets 10
eejay56 Oregon Trail Rally Triumph 6
E TR6 On the trail of a TR6 parts car Triumph 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
C Steering Arm Castle Nut Torque Austin Healey 5
WHT Rocker Arm Shaft Replacement Austin Healey 21
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
W Steering Arm Colors Spridgets 1
R TR6 Lower A-arm trunnion bushings Triumph 18
D MGB Rear Suspension Damper Link Arm MG 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
Rob Dodge Trafficator arm issues. Jaguar 2
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
Rut TR4/4A A arm orientation Triumph 2
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
D rocker arm assembly Austin Healey 14
G TR4/4A Wiper Arm Question Triumph 13
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
J BJ8 arm rest with compartment Austin Healey 1
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
A TR5/TR250 Trailing Arm Question Triumph 9
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
