Hi,
I need to buy a new rocker arm shaft since the one in our car has a groove worn into it by one of the positioning springs. Rocker Arms Unlimited advised me to source a new rocker arm shaft and send it to them before they rebuild the assembly. They usually only reclaim/hard chrome good condition OEM shafts which may not be available used; and they have no information on new shafts.
BTW, our oil pressure is 60 PSI at idle, 50 psi above 2000 rpm when hot and 25 psi at idle when hot (using 20-50 oil). So, we are only having the assembly rebuilt due to the groove being worn into the shaft.
I have not replaced a Healey rocker arm shaft before and I am not familiar with the quality of new replacement shafts. Is it better to (i) buy a new (not chrome plated) hardened shaft, (ii) find a new rocker shaft that IS hard chrome plated or (iii) try to find a used OEM shaft that Rocker Arms Unlimited can reclaim and hard chrome.
Thanks for any thoughts and recommendations.
Regards, Bill
Regards, Bill
