TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn?
karls59tr
Bronze
It's my understanding that once the rocker arm surfaces are worn you can not get an accurate reading with a feeler gauge. Where is the dial gauge mounted and what is the procedure for the adjustment?
groupdeville
One trick that I happened to read recently was to just use a very narrow feeler gauge blade for worn rocker arms. The gauge would need to be narrow-enough to fit within the worn area of the rocker arm surface, but if so, it would give you a true reading of the actual clearance. Haven't tried this technique yet myself, but it seems like it would work well.
K
karls59tr
Bronze
I don't mind modifying a feeler gauge for that purpose. Do you think 1/4" wide would do the trick?
Madflyer
When getting that much wear you could be not getting much oil to the head. I added an extra oil line to head there are kits for most of our cars 4 and 6 Cyl but rockers are not sleeved just steel to steel so wear to shaft and rockers will give you a bit less oil pressure also so less oil to all rockers. I was going to install bronze oil light bushings but rockers $11.00 each and machine shop would have been most of $20.00 each. A plus for extra oil to head is also cooling. Not mush reason to regrind rockers if rockers and shaft are worn that much.
This makes me want to check mine before driving season I guess and a tune-up may be called for. Madflyer
robmate
Hi karl, Procedure I use is this, as you may know, you have to adjust tappets when cams are positioned on their lowest point or base. Given that #1 and #4 are companion cylinders, so are #2 and #3. Meaning they are in time with each other but doing opposites and so are the valves. #1 exhaust valve and #4 ex valve, #1 inlet and #4 inlet and so on, all doing opposites.
I start with #1 exhaust valve, it will be fully closed and can be adjusted when #4 ex valve is fully open, in down position. Then do the next, turn engine over till #4 inlet is open and adjust #1 inlet. You can save a bit of effort by doing more than one at a time when you see other valves that are open to adjust their companion valves. Mark off the ones you do with dab of grease. I normally remove plugs and select 4th gear and pull car along to turn engine over.
Hope this helps! Rob.
2liter4cyl
Bronze
Any engine , 4 cyl, has the same firing order: 1,3,4,2. My Toyota Corona repair manual of 1972 is what I have since used: Set the timing mark at TDC and check for closed valves It comes in one of 2 sets: #1235 and #4678. Now adjust the closed valve set, Rotate the crank 360 degrees and adjust the NOW closed valve set. You can adjust 4 valves at a time & with one rotation of the crankshaft. It is all 0.010" making it easy.
LeT
Platinum
Other wear points need consideration as well as rocker-to-valvestem. The rocker bushings and shaft can also become a bit ovaled. Removing the shaft assembly and doing a comprehensive inspection is not a bad idea if wear at the rocker contact faces is evident.
James A Martin
Karl,
I'm not sure about thin feelers or dial indicators, I installed new Valves and push rods, polished my rockers as flat as I could and set the valves with a normal feeler gauge....
I Found this method somewhere on the net last year. It is simple and probably just 'in other words'. I'm not sure who posted it.
<Re: setting valves on TR3 and TR4
I've used the following method since finding it in a club (I think it was the VTR) newsletter, which in turn I think got it from a Toyota publication: Turn engine to #1 piston TDC by aligning the timing mark and pointer with the distributor rotor pointing to the #1 plug contact. Set both intake and exhaust for #1, Intake for #2, and exhaust for #3. Turn engine one complete revolution (again aligning timing mark and pointer). Set exhaust for #2, intake for #3, and both intake and exhaust for #4. If you have a cam other than the original stock cam, get the clearances from the cam grinder and set them as best you can within the given tolerances. I have checked this procedure with a couple of sports car mechanics who say it should work. I know of no shortcut for the TR6 -- we use the rule of 13. All engine numbering begins at the front of the engine.>
Jim
poolboy
Might be time to replace or have them resurfaced if you can't set the lash with a feeler gauge.
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
T Anyone using an LED light like this Triumph 39
