Looking for recommendations re using a Seacan for vehicle storage
twas_brillig
I might have the opportunity to install a Seacan (probably 40 ft long) in a rural area for storing 'stuff' (including cars). I'm assuming one or more Bugeyes (possibly one above the other) and building shelves for parts. I expect that there will be minimal site preparation (i.e. it won't be perfectly flat) and we'll lay out some 8 ft long pressure treated 6x6s or 8x8s crosswise for the can to sit on so it will be slightly elevated.
Any wisdom regards: mice? ventilation? (we live in Western Canada. I'm thinking cutting some holes and adding screened vents would be a good idea, but???); lighting? thoughts on attaching shelf mounts/lifting hooks to the inside of the can? roof strength for snow? walking on the roof?
BigGreen
A metal container will always cause condensation in a continental climate. Insulation and light ventilation or use without insulation and a lot of ventilation is necessary.
equiprx
I would not rely on any wood product for a foundation.
Any reason to not pour a slab?
T
twas_brillig
Total Cost (reason for no slab) . I chatted with a supplier today, and his point was that the modules are designed to stack, with the load concentrated on the corners where they are connected, so (particularly for my light weight load) he suggested supports (to keep the bottom of the can out of the dirt) are only required at the corners. He cautioned that the only real concern is to avoid 'twisting' the can as that could cause the doors to jam. So, we'll hopefully get it into position, and get it levelled right to left at each end, with a slight downward slope to the entrance.
Bayless
Pressure treated wood will last a long time on the ground but for an even longer life you can usually find used railroad ties.
T
twas_brillig
We're in quite a dry climate and will not have power available (other than a solar installation). I can potentialliy get some used railway ties, but they are presumably creosote treated and I'll want to have a look at the possibility of the creosote leaching out, as the location is adjacent to a small river.
I expect that I'll add a side mounted 'turbine' vent at the door end, and a pair (one on each side) of ordinary vents near floor level at the far end. Everything screened to keep beasties out.
HealeyRick
From what I've read, condensation, interior heat and critters will be your biggest enemies. Some folks install solar-powered vent fans. Complaints mention mold as a big problem, literally destroying the contents. This really is a case of Google being your friend as there are a lot of people with experience using them. I'd also be concerned with security if it is going to be unattended and even if I addressed the condensation issue, I'd want to be checking on the contents regularly to make sure bad things weren't happening to the insides rather than just shutting things up and leaving it for several months at a time.
60TR3A Looking for Recommendations for Garage Lift Austin Healey 9
Brosky Looking for paint recommendations Triumph 15
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
