Using Midget Suspension parts on Nash Metropolitan
thebronc4019
I was looking in the Victoria British Catalog at the lower control arm for an MG Midget. The lower control arm set up looks identical to the later Nash Metropolitan configuration. The Nash uses identical components for the lower and upper arms with respect to trunnion pins, trunnion pin locks, bushings, cork grease reatiners etc.. I am convinced that if I bought 4 sets of components for an MG Midget lower control arm I would have what I need to do my Metropolitan front end.
Do you have any knowledge as to the compatability of the above-mentioned parts? Any help would be greatly appreciated.
thebronc4019
T
thebronc4019
PeterC,
I greatly appreciate that information. Might you know the outside diameter, inside diameter and length of the lower control arm Bushings?
DNK
PeterC said:
The trunion pin, locks, and cork are the same for both cars.
Peter C
Now why would anyone know that :confuse:
T
thebronc4019
I will take that as a NO. I wanted to see if the MG bushings fit the Metropolitan control arms. I will seek this information elsewhere.
PAUL161
Re: Using Midget Suspension parts on Nash Metropol
If anyone would know that, Peter Caldwell of World Wide Auto Parts would be one of them! The gentleman is well known for his expertise in rebuilding suspension parts for these vehicles. JMHO. PJ
swift6
I agree that Peter would be one of many experts to ask. And he has already weighed in with the above post. "Peter C" is Peter Caldwell from the looks of it.
PeterC
thebronc4019 said:
PeterC,
You mean the trunion pin? Or the inner A-frame bushings on a Midget? Mets and Midgets are different. Midgets use a stamped steel lower A-frame . BUT, the trunion pin, the threaded thing that has 2 diameters, are the same for both cars, except the Met has twice as many.
Oh, and I visit here generally during business hours, so unless I get a PM or direct email, I don't get to see the question.
Peter C (aldwell)
T
thebronc4019
I mean the inner A frame bushings on the lower control arm which appears to be identical to that of the Midget. I went ahead and ordered the trunnion pins, locks and cork seals in quantity to do all 4 control arms as the components for the upper and lower control arms are all the same on a Met. I went ahead and ordered 16 lower inner bushings as I am confident they will also fit. I will let you know what the outcome is once the package arrives. Thanks again for your assistance.
Phase #2:
Does anyone know a NAPA part numbers for the inner and outer wheel bearings and the corresponding seals for a Midget, I believe there are two different sizes depending on the model of the Midget. I would like this so I could take my bearings to the NAPA store and possible see if they match the Midget hearings.
Thanks for any assistance anyone could provide.
V
vagt6
And if I'm not mistaken, a Triumph gearbox in the Nash Metropolitan, too.
A friend recently did a frame-off resto of a Nash Metro to look just like the "Nancy Drew" car.
Really cool car, that! :yesnod:
Billm
Everything that I know about the Metro is that the transmission is a stock MGA transmission with a special side cover that locks-out first gear so that you have "full syncro 3-speed transmission" (selling point). To compensate for the taller "low" gear they put a ridiculous 4.55 (?) diff in it (killed the freeway crusing!!).
Friends of mine with Metros would take off the side plate, grind off the "lockout boss" and have a 4-speed again.
BillM
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
T Anyone using an LED light like this Triumph 39
