TR4/4A Getting electrical shock from horn button when using the horn.
jimmyr
Member
New owner of aTR-4A, and am getting a kick back electrical shock when pressing the horn button. Have tried adding a diode to one of the horn relay terminals, but no luck quenching the the problem.
bobhustead
I would have been fairly sure that, absent conduction directly thru an opening in the skin, it would not be possible to feel a shock from a 12 volt dc source.
Bob
George_H
The diode should be on across he relay coil. You could even put one across the horn switch. Be sure to put in the correct polarity.
J
jimmyr
Member
Correct, I must have put the diode on the horn side of the relay as the terminals are not marked. I will move it over to that terminal. The car is a negative ground system. BTW, the inductive kickback from a coil equates to several hundred volts thus the shock conditions.
sp53
12v DC will not give an electrical shock; the voltage is too low. It will burn you from the heat of high amperage and make your wires and skin smoke. One must always keep the smoke inside the wires. Perhaps you are actually feeling heat and confusing that for a shock. So let the device honk. If it does not honk, it will burn you or blow a fuse or catch fire.
steve
J
jimmyr
Member
All fixed, I moved the diode to the relay coil wire that goes to the horn button. The horn button on the Moto steering wheel is metal, so you are in contact with the relay winding and the inductive kick back that measured 300V on my VOM - so this pulse was felt.
Popeye
Bronze
Ah - metal button. Thanks for the clarification - and happy you resolved the issue! (A horn is supposed to "jolt" other drivers to attention... not yourself!!!)
Rocky_LC
I had that problem on my TR4a, especially one of my bare arm was resting on the metal window ledge.
I was living in Fort Walton Beach Florida, humid out there.
Lots of surface area for conduction through your skin. And the horn button was metal.
Sarastro
Interesting. I would have thought that the horn inductance wouldn't be high enough to cause this, but obviously it is. I didn't know that TR4s once had metal buttons; mine is plastic. I'm surprised the factor did that; it's really asking for trouble.
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
Jim_Gruber So what is your LBC getting for Christmas Spridgets 39
