Getting hot in the car [AH3000mk3]
Danne
Member
Hi, well this is the first question, of probably many to come
I got my BJ8 two days ago. There are some things that don't work in the electrics. The panel lights dont work, the washer fluid doesn't spray - the radio, the heater/fan doesn't work either.
I don't have a clue how to fix all this, but I have to start somewhere, and that is with the heater i think, since it gets very hot inside the car when I'm driving. I don't know where it's coming from. I feel hot air streaming from the clutch gasket (when I hold my hand on the clutch knob). Sometimes more, sometimes less. But it feels that if it was just that, it could not heat up the inside that much. I mean, I'm sweating while I drive with the top down... It also gets a bit hot next to my right leg (from whats underneath the carpet). But it's not THAT warm, so it couldn't cause this heat i think.
Anyone have a clue what could cause the heat?
/Danne
DerekJ
Danne,
The first think to be aware of is that Healeys do get hot inside. I assume the engine is not overheating and is working normally. One thing you can do is stop the water flow to the heater by closing the tap on the engine block on the right hand side, near to the bulkhead. The heater controls themselves are confusing. The hot air flow is cut off by pulling out the knob not having it pushed in. Cold air flow is also activated by pulling out the air flow knob. So for no heat and cool air both knobs should be pulled out.
Regarding the electrics. You need to acquire a good wiring diagram. Look on e-bay, there are some full colour versions in larger formats that some people are producing that are much better than the the one in the workshop manual. Its then just a question of testing the wiring circuits until the faults are found. Its actually not as difficult as it might appear.
Welcome to the world of Healeys, you will get lots of help on the forum
hoefnix
The air that flows from the enginebay and transmission under the car is very hot.
I experienced the same when I got my mk3. After a week I noticed that there was no plug in a hole.
Just under the dash on the transmissioncover there is a cross cut in the carpet. Under that cross cut you will either find a plug or a hole. If the plug is missing buy one for a few bucks and it will lower the temperature.
(the hole is get access to the oilcheck for the transmission).
All other holes in the transmission cover will also spit out very hot air if they are open :smile:. So the oil check hole, transmission stick and handbrake all punch through the cover.
Danne
Member
Thanks for the welcome:smile:
Ah ok, good to know that they are hot inside per default:smile: I will try to cut off the hot water like you said Derek. If I may ask a question about the heater/fan; should it be startable when ignition is on?
I do have a wiring diagram over the electrics, but it looks like jibberish to me, but I will try to learn. Right now the electrical system is a total mess with lots of cut off cables. There are some relays that don't even have cables connected, and I have no clue what they are for. How do I check the cables and circuits. Do I have the ignition on while testing? (sorry, I'm very new to this).
/Danne
Danne
Member
Thanks hoefnix! I will definately check if that hole has a plug! That definately adds to the heat. Sometimes it streams more and sometimes less. It might be depending on the speed.
/Danne
andrewss
Danne, there are a lot of Healeys in Sweden and a lot of people who know Healeys very well.. If you have Facebook contact Anders Pettersson who knows Healeys better than most. he can help you..
R Rear brakes getting hot!? Spridgets 4
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
