How important is getting the float height correct on SU HD6 carbs?
fishyboy
Hi All,
Following my rebuild of the HD6 carbs (thanks for the advice on my previous thread) on my BT7 I have been looking at the float bowl height adjustment. According to my manual the height should be set to 11mm (using a drill bit or similar). At the moment the forks are about 12-13mm. dies this mean that the fuel level will be 1-2mm to high in the jet and that the mixture will me too rich? Should I adjust to exactly 11mmor leave well alone?
Thanks
Phil
oxford
Hi Phil
yes! It should be set to 7/16" I believe. If it isn't the fuel will be higher in the jet. If it says that in the manual it's probably a good idea to adjust it.
Matthew
Lambdaman
If correct height is 11mm and yours is 12 -13mm, that means your float will be 1 -2 mm lower, as this distance is measured from the top flange of the cap, therefore the level will also be 1-2mm lower in the jet as both are equal. So if this is the case your carb will be running lean.
John Turney
It's critical that they be correct as specified and they both be the same. Otherwise, you won't get it to tune correctly.
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
John Turney An Important Healey Up For Sale Austin Healey 1
Basil Important Note about Search Function - Please Read Other British Cars 0
Basil Important Note about Search Function - Please Read TVR 0
Basil Admn Note Important Note about Search Function - Please Read Triumph 0
Basil Important Note about Search Function - Please Read Sunbeam (Rootes) 0
Basil Important Note about Search Function - Please Read Spridgets 0
Basil Important Note about Search Function - Please Read Rover / Land Rover 0
Basil Admin Note Important Note about Search Function - Please Read MG 1
Basil Important Note about Search Function - Please Read Lotus 0
Basil Important Note about Search Function - Please Read Jaguar 0
Basil Important Note about Search Function - please read British Motor Corp 0
Basil >>> Important note about the search function - please read Austin Healey 0
Basil Important note from Basil Other British Cars 0
Basil Important note from Basil TVR 0
Basil Admn Note Important note from Basil Triumph 2
Basil Important note from Basil Sunbeam (Rootes) 0
Basil Important note from Basil Spridgets 0
Basil Important note from Basil Rover / Land Rover 0
Basil Admin Note Important note from Basil MG 0
Basil Important note from Basil Lotus 0
Basil Important note from Basil Jaguar 1
Basil Important note from Basil British Motor Corp 0
Basil Important note from Basil Austin Healey 0
D TR2/3/3A Why it is important to change brake fluid Triumph 4
Bayless Missing important part Spridgets 0
T Birthdays and Important Anniversaries Austin Healey 0
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
T TR2/3/3A How important are matching rear shock links? Triumph 9
rick_ingram General MG IMPORTANT - If you attended MG2014 in French Lick, PLEASE read this! MG 1
DerekJ Important, documented, 1953 DHMC modified 100 Le Mans for sale Austin Healey 8
F T-Series Looking at a 1955 MGTF today- what's important? MG 8
R Important Discovery MG 6
rick_ingram MG2011 - Important Announcement MG 0
germanmichel Tensioner housing oil orifice important ? pic Austin Healey 7
ncbugeye How important is rubber boot on clutch M/C Spridgets 9
healeynut The Most Important AH Post Ever Austin Healey 12
2wrench Simple yet important engine timing questions Triumph 11
bravenrace How Important is a Header? Triumph 24
regularman Important question [I might have just screwed up] Spridgets 8
regularman Some important info that some already know... Spridgets 1
G a small but important milestone... Triumph 11
rick_ingram MG2006 - Trailer Info - Important! MG 16
rick_ingram MG2006 - IMPORTANT INFO! MG 0
M How Important Is Fuel Cooler in Air Cond. 87 XJ6? Jaguar 6
rick_ingram MG 2006 Up-date - IMPORTANT! MG 1
Geo Hahn When You've Run Out of Important Things to Do... Triumph 11
TypeRboy Important Vauxhall manual on e-bay Other British Cars 5
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
