TR2/3/3A getting the circlip off 3rd gear
sp53
I am having a difficult time getting the circlip off 3rd gear on this transmission that I am working on. I could not get the bearing of the back off the main shaft, so I am trying to remove the circlip to slid the gears off that way.
My snap ring plyers are not strong enough and broke. I am not sure what the tool looks like I need, probably so kind of needle noise plyer that works opposite, so they will open the clip in the confined space that it sits. Does any have a picture of some kind of tool that will work? The tool needs to be strong, so probably pricy, so I want to buy the right tool.
steve
bobhustead
Go on the SnapOn site and look at SRP4. I bought one 55 years ago when employed as a BMC mech. Still have them, so I would rate "unbreakable". You may find a similar at NAPA. 85.00 ain't cheap, but as my poor old mother used to say (no, really), "If you need the tool, buy it".
Bob
CJD
You may still have to use a small screw driver to encourage the snap ring back once it is spread. This is the most difficult part of the entire tranny rebuild. I recommend buying a couple , as I often destroy them removing...and occasionally installing.
CJD
Also, post number 12 here shows how the end of the pliers look...
mctriumph
Regardless of what tool you use, this part is critical and must be refreshed. If you spread it too
far with plyers it will be damaged. The Churchill tool is the bomb for sure. If you dont have
one, become friends with some one who does. He is certainly a cool dude! Failing this, be the dude!!
Mad dog
Sarastro
It's so easy you'll kick yourself when you see how. Go here:
and scroll down a bit.
Of course, the default option is to use the Churchill tool. But you might have trouble finding one.
mrv8q
Steve Maas is my new hero. What an amazing website! Thanks, Sarastro, for linking that.
S
sp53
Thanks you guys. It looks like the tool that bob posted is the older brother to the one John posted. I had reassembled that transmission out of a few I took apart 25 years ago to make a one good one. I forgot how difficult that clip was to remove. I took the transmission back apart to refresh my mind and see what shape the gears and stuff are in before I moved to the building one I want to use on this project. this trans had the old bearings and everything was scavenged
I got the clip out last night with a couple of semicircular picks and a long skinny screw driver. I took the ½ circular picks and put the tip in shaft grove between the clip and shaft then rolled the pick tip in behind the clip and that rolled the clip out of the grove on the open ends. From there I keep rolling the clip out and prying the clip up with the long screw driver. Of course this was after I broke my snap ring plyers and had a couple of nervous break downs. The circlip tool would be best and I will probably get one. I did not like the clip rubbing on the shaft. Oh yes MD I will be your Friend for a Churchill tool.
I had typed this up before I read the article Steve had posted. I pretty much did the removal the same way after 4 hours of failure. I will say getting the clip out that way is no fun either other than the final success. I will probably spend the money for the tool. Maybe, I am so cheap it hurts sometimes, but the tool will keep the drag off the shaft, but it depends on how well the tool holds onto the clip. When I did get the clip out of the grove, I slid the clip up by hand and I could not see any scaring. Replacing the clip is probably the correct way. I will buy one and look at, but the old slip did not lose its shape and the steel feels solid which will probably be more than the new one feels
steve
mctriumph
I do not have this tool, but an old and dear friend does. I always take him a beer(home brewed).
I do his bodywork. He fixes triumph tranny's I wish I had the foresight to buy one back in the day
Mad dog
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
Jim_Gruber So what is your LBC getting for Christmas Spridgets 39
