Help Needed, getting those 1/4 Eliptics out of the spring mounting box
Jim_Gruber
Team,
I managed to drill out the broken bolts on my BE on my RR Spring, and spring dropped down easily, and I have also cleared all of the debris and detritus out of the Spring box. No wonder BE's always rust out down there. A Rust magnet. Fortunately the Spring Box is solid, this car has been in inside storage and dry the last 35 years. So when I try to remove the spring it gets hung up on the top shackle plate. I can move it around, in and out, and it gets so far and that's it. I cannot pull it out. What are the tips and techniques to get it the rest of the way out of there that folks have used. It moves freely in the cavity just can't get it the last 2-3 inches out of there. Thanks in advance.
PS I hope you don't tell me I need to drill this bad boy all of the way through. It's not hanging up on the nut but on the ridge of the top shackle / backing plate. Of course if drilled all of the way through the shackle plate would slide off....Then a question of how you get it back in there and get the backing plate in place. Advice needed. Thanks
TulsaFred
Oh yeah, I remember. Same thing happened to me, I had forgotten that little bit of fun.
I can't remember now how I solved it. I seem to remember it "almost" came out before getting hung up, as you say.
Maybe you can get a sawzall blade in from above to cut off the bolt under the threaded plate. A drift from below might provide a little clearance under the plate.
If I remember I'll post it.
I don't think putting it back is much of a problem. The leaves will be able to be shifted a bit.
Gerard
The one time I had this happen. You might need to use a Sawzall to cut the bolts off just under the plate. The spring will NOT come out with the plate in place. The opening is just not tall enough. What you've probably done is broken of the heads and you have an inch+ left in spring. Drilling out would not only be a nightmare, but you'll probably damage the holes in the spring itself. However, if the bolt sheared farther up the shank, what you can do is undo all the clamps that hold the leaves together, and try removing leaves starting at the bottom. if you can get 2 or more leaves out, you'll be able to drop the spring lower and clear the plate.
lewmac
Hi Jim,
If I recall, it won't come out unless that big fat U bolt shackle is outta there.....some how you have to get the U bolt shackle nuts of and then tap the u bolt up until you can pull the top out and remove the u bolt. same process in reverse when assembling the spring. Mounting plate first, then Q e spring and then shackle bolt.
Cheers
Lew
Jim_Gruber
Jim_Gruber
The U Bolt is out. I did drill up enough into the spring that I could possibly separate the bottom leaf. If not can drill a little more. Are those clamps available not sure if they can be unbent and reused or not?
I'll try tomorrow morning to see what I can do with the Sawzall. will make sure nothing left on the bottom of the bolts I drilled out that is sticking down. Also will try to cut off top of the backing plate. Seems daunting but SawZall can do some wondrous things.
Rut
Jim,
these are the original bolts and bracket as well as the spring box. The bracket is in the forward most position and lies directly behind the bulkhead bump under the stiffening support. If you will be replacing sheet metal in this area you can attack it from the front, if not a sawzall under the bracket between the 2 bolts is the way to go. Good luck!
Rut
Jim_Gruber
Jim_Gruber
Rut, the area around the spring box has already been repaired. If all else fails I guess I could cut it open from the back/bukkhead side. I now see know why this spring was never removed when bukkhead repair work was done 3; years ago
Jim_Gruber
Jim_Gruber
Make tgat 34 years ago. A significant smount of rusty yuck was removed from that spring box. Ibelieve it is sound metal in there but won't know until I Get it apart.
Jim_Gruber
Jim_Gruber
Gerard, that would work but there is that centering pin that locks the entire stack together. Likely that will become a casualty of the SawZall as well as the backing plate. This is going to be interesting. If all else fails I can attack it from the bukkhead side and weld back up. Thanks.
Gerard
I forgot about that, but as I recall, there is a nut at the top you might be able to get at. I don't have an assembled car here to see how much access there is. Otherwise, you may need to cut the bottom off that as well. You'll need to be able to raise up the plate at the top to gain access. As I recall now, I'm pretty sure I ended up cutting the blunt end off mine to get it out.
Rut
Jim,
What Gerard says...the pin in the center has a nut which is usually rusted away and you need to lift the 2 bolts high enough to give you a gap. Use a punch to drive the 2 cut bolts up as far as they will go and have at it with the saw. The replacement parts will need to be beveled on the front end to clear the bulkhead on reassembly or you will never get the new bolts to line up!
Rut
Jim_Gruber
Jim_Gruber
Thanks guys. This is going to be a challenge. I'll start with the SawZall and see what I can do. May need to wait until tomorrow as we've got 25 people coming to the house for Colleen's Birthday today. That will too tge priority list today.
Jim_Gruber
Jim_Gruber
OK 20 minutes with the SawZall on the side of the bracket has made a 1/16" cut. Cannot get access from the side to directly get under the backing plate. Need to get room on the side, hence my thought on cutting directly up from the side of the spring. But at this rate will be hours and hours of cutting and changing blades. Hmm could a 5" cutting wheel on my angle grinder with the guide off get up there and trip off the side of the backing plate?
Thought of trying a drift to punch out the springs but now that the spring is loose and disconnected in the spring box, no way to get proper leverage from below. Can't even see the holes drilled that freed up the spring from mounting bracket. Need some more thought gents. Ther bulkhead side with supporting brace is no little piece of steel sheet metal to cut through. Multiple welds and in fact you can't even see where the welds are to even think about separating that piece from the bulkhead. Need more ideas guys. Thanks.
Jim_Gruber
Jim_Gruber
I've got a new of 10 leaf spring that were promised to go with parts car. Neighbor has a cutting torch and a plasma cutter. I may need him to come over for a consult on getting this SOB out of there. Would like to retain 15 leaf if possible.
Gerard
OK 20 minutes with the SawZall on the side of the bracket has made a 1/16" cut. ...
.... Need more ideas guys. Thanks.
If it's taking you that long to make that little progress, you need a better blade.
mightymidget
not sure exactly where you are at but I tell you what I did, it may or may not work for you.
I got a large pipe wrench, had 18-24" handle on it, gripped the spring and twisted in box 90 degrees. then the spring came right out.
You need to drink a dose of ****&vinegar to give you the push to twist spring in box. Good luck
TulsaFred
Great idea, Mighty Midget. The brute force method. I like it.
Or, about a 1/2 inch bolt, or 8/16, at 1/16 per 20 minutes = 160 minutes or 2 hrs and 40 minutes with the sawzall on each bolt...
I'd get the big pipe wrench. Biggest you can find. Harbor Freight has some big ones for cheap.
I like the 48 in one!
https://www.harborfreight.com/catalogsearch/result?q=pipe+wrench
Jim_Gruber
Jim_Gruber
Plan for today. Use SawZall with new blade and continue cutting from the bottom along the side of the spring and cut off one side of the top bracket. Then use brute force method. Since car is one jackstands got to be somewhat cautious with force exerted. Slicing off one side reduces width making it easier to turn on it's side and slide out. Thanks team for help and support.
Jim_Gruber
Jim_Gruber
SUCCESS! A new Method for Spring Extraction. I followed the tips provided by Mighty Midget. I got a 12 " pipe wrench and placed on the end of the spring. Gave a tug, thought no way this is going to go, repositioned the spring a little further in the box and voila the spring turned right over on its side and slid straight out. Save this one in the annals. No more cutting. just drilled the bottom of the spring mount so the bolts were free to move and it turned right over with a little leverage. Thanks to Mighty Midget for helping me defeat British Engineering. Now to clean out the remaining rust and see what I have in there.
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A help needed! fuel problem Triumph 25
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
Lukens TR2/3/3A help needed Triumph 6
A Fuel Gauge - Help Needed Austin Healey 18
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
M Help Needed. Alternator Question Spridgets 14
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
Brooklands MG Parts ID help needed MG 4
abarth69 quick help needed Spridgets 3
