TR2/3/3A Front windscreen help needed. TR3A 1960
Tinkerman
There seems to be no gasketing between the stanchions and the body of the car. Seems to me that a rubber gasket would be needed?
Also in a previous BCF tip MKUTZ mentioned "for this one do a dry fit of the glass in the two part frame--also make sure that the two little steel bars on the side of the upper framehalf are installed and the holes are freshly tapped". I see no mention of any little steel bars, in the catalogs or the parts listings, could that be the corner brackets?
I appreciate what ever thoughts and help you can pass my way.
Cheers, Tinkerman
Geo Hahn
Deja Vu
Possibly referring to the tenon plates? Tenon plates are item 51 here.
TR3driver
Great Pumpkin - R.I.P
The early Dzus stanchions had a groove with a wad of material in it; but AFAIK the later ones didn't have anything except the tag end of the seal across the bottom.
Personally, I wouldn't even think about chasing those holes with a tap. The brass frame isn't all that strong to begin with, and there is a lot of force on those 3 little side screws. It's probably best if you not think about what happens if they fail at 75 mph ...
Tinkerman
Tinkerman
Someone mentioned that I should get the rear view mirror mounted before mounting the wind screen. No problem I shall do that, however what about the vent lid? Or doesn't it matter?
Thanks, Dick
Geo Hahn
Shouldn't matter -- I've done both with the windscreen in situ though I suppose these bits are somewhat easier to do now while the screen is not there.
TFB
I believe the steel bars refered to are the 4 steel blocks that mount to the inside of frame for the upper 2 stanchion screws.The 4 blocks are held to the frame with a small countersunk screw,and have the hole for the 2ba screws.The bottom screw threads into the corner bracket.If the threads are stripped you can replace the blocks.THis is for post 60k.
Tom
TR3driver
IMO, doesn't matter much. Might be fractionally easier without the windscreen. Get the linkage hooked up before you install the lid, though.
TR4nut
Tom
I'm with Tom - some frames have different setups but I'm thinking they are talking about those blocks.
J J-H Front Windscreen [glass] Replacement Restoration & Tools 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
craigshealey3000 Front End Shake Austin Healey 31
