Front End Alignment
Xavier70
Another question, still working on getting my BJ7 back on the road. I put the car on the ground today. Appears the alignment is noticeably off. The RH tire is definitely toed out. LH reasonably straight. No adjustment left on the tie rod. New Moss tie rod ends, used the old tie rod. Any ideas?
X
Xavier70
Don’t think so. I replaced the driver side steering arm (attached to steering box) and the steering lever attached to the swivel axle as they were both bent.
X
Xavier70
Also I’m pretty sure the car took a significant hit on the driver’s side. The outside bolts that attach the driver side shock had been replaced with larger bolts so I suspect the previous owner hit something hard enough to tear the LH shock off . He had to fix this but left the bent levers on the car. I replaced these when I rebuilt the suspension.
X
Xavier70
I have reviewed the info posted and concluded that I may have reversed the steering levers. Here are a couple of photos of my levers with the new moss tie rod ends removed. Hopefully you can see these well enuff to tell if I have them reversed.
X
Xavier70
Okay, I'm back on the front suspension issue. Here's a little more info on my front suspension issue (sorry, this might be a little wordy). As suggested by Bob Haskel I think I may have the wrong steering arms on my car. I found a thread from Steveg from March 2020 that identified the part numbers for the steering levers. Per this thread (the diagram) the steering lever on the RH side should be Pt No LB 6277, LH should be LB 6278. ( I think this is correct per Steveg post). Based on this info I checked the parts on my car now. On the RH side the number is definitely LB 6277, on the LH side the number is LB 627??, I can't decipher what is on the forging. The original lever on the LH side was bent so I replaced it with one I got from a friend. The original lever from the left side of the car is clearly marked LB 6277. When I replaced this lever I didn't know about the part numbers so I just went thru a bucket of levers my friend had and picked one that appeared to be the same (i.e. the one with Pt No LB 627??) I now suspect that I have LB6277 levers on LH and RH sides of the car which according to Steveg is wrong and is the cause of the toe in issue I see. A rough check of my "toe in", shows that the front side measurement about 1.25" greater than the rear, ouch! I have adjusted the tie rod as for as it will turn in the CW direction. I am going to try to get back to the bucket of levers and try to find a lever with Pt No LB 6278. In the meantime, looking for any suggestions to help me unravel this. Obviously, I can go to Moss and buy a LH lever (~$299) or Welch (~$150). Before I go there just looking for some info from more experienced restorers.
Also, Steveg mentioned a parts list on this site. I looked but couldn't find this. I'm a newbie so not really experienced at navigation on the Forum.
On a positive note I did drive the car as is sans front shroud and fenders, with the Hendrix Wire Wheel tags still attached to the wheels. Did great, looking forward to finishing this long term project. I'll post that video later so you can see a redneck from Georgia driving a partially restored BJ7.
Thanks Mucho
Skip
X
Xavier70
Per my last thread here’s my first drive of my Healey. Everything seems to work fine. Some fine tuning needed but I’m definitely happy. Been about 7 years coming.
X
Xavier70
Here’s a link to the video. Hope this works for those interested! Novice user indeed!!
red57
Hi, You cannot run two right side steering arms - the tapered hole for the outer tie rod would be upside down and you could not insert the tie rod from the top. The steering arm must angle slightly upwards, and the tie rod end must insert from the top with the nut on the bottom.
If your problem is toe-out, then you probably need to shorten your cross rod because the tie rod ends currently available are too long.
See this link to an earlier thread - good read. The first pictures show the correct orientation of the steering arms and post #29 (2nd page) shows a picture of stock vs current tie rod ends. Toe in issues
X
Xavier70
Thanks. Earlier post has photo of my currently installed levers. 6277 on RH and 627? on LH. I’ll end up shortening the rod but wanted some added input.
bob hughes
I would stongly recomend that you do not drive that car with a large toe out. When I first bought mine I did not realise that the car had a toe out and after some quick miles in the first week I noticed rapid wear on the front tires. Took the car around to the local tire shop and there was 1/2" toe out. Ouch!!
:cheers:
Bob
X
Xavier70
I don’t plan to drive it further. The video was. 2 minute, 300 yd spin primarily to make sure the Toyota transmission works. It did.
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
B TR2/3/3A Front end alignment Triumph 23
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
S TR2/3/3A Front end alignment and tire wear Triumph 9
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
O TR2/3/3A TR3 front End Alignment Triumph 8
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
L Front end alignment Austin Healey 6
DrEntropy Anyone interested in DIY front-end alignment? Restoration & Tools 14
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
SCguy TR4/4A TR4 front end alignment Triumph 2
ronzet Speaking of front end alignment MG 20
G Front End Alignment Spridgets 41
PAUL161 Front End Alignment MG 8
bluemiata90 Brake shims/Rough front end alignment Triumph 4
R Front end alignment Triumph 2
M Spitfire Alignment on Spit Front End Triumph 6
G MGB '71 MGB Front End Rebuild MG 2
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
