MGB Rattle under front end?
Joe Reed
I've got a fairly loud rattle under the front end of my '78 that is driving me nuts. It sounds as if it's coming from the right side of the suspension, but I can't find the cause.
It only occurs when hitting a pretty sharp bump at speed - like a pothole or a speed bump. It sounds like pretty solid metal-on-metal...not like something thin like sheet metal. It does not affect the handling at all, and I can't feel it through the steering wheel.....no symptoms other than the sound.
I've got the car on stands with the wheels off. Crossmember pads are in place and the crossmember is tight. Suspension bushings are in good shape (Superflex blue bushings) and everything is tight. Sway bar bushings are in excellent shape. Calipers are not loose. Bumper is solidly attached.
Any ideas other than just turning off my hearing aids??
Mickey Richaud
Joe -
Shock mounting bolts? I had a similar issue and found a couple weren't tight.
Mickey
Joe Reed
Joe Reed
I'll check those again. I think I may drop the spring and see if I can find anything loose. Maybe the tension of the spring is masking something....
Joe Reed
Joe Reed
All the bushings are Superflex blue poly installed about 8000 miles ago...
JPSmit
asking the obvious I know but have you tried bouncing it on the ground?
Mickey Richaud
One more thought: Check lube on upper and lower points on the kingpin.
Joe Reed
Joe Reed
Mickey nailed it in post #2....shock mounting bolts were just slightly loose. The thunk is gone :smile:
One lesson learned here is to make notes of what you've done or checked if several days pass between the times you get to work on the car. I could have sworn I checked them last week, but I didn't take notes...and I obviously can't remember everything from one week to another. Funny how "I need to check those bolts" one week becomes "I checked those bolts" in your memory by the next week.
Mickey Richaud
Glad you found it! Can't tell you how many times I've gone over tasks I'd gone over before and found I'd actually missed something.
R Fender Spear Potential Rattle Austin Healey 6
K TR2/3/3A Timing chain rattle on start up? Triumph 2
M MGA MGA Engine Rattle MG 10
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
BoyRacer Rattle can Healey Blue paint Austin Healey 2
KVH Rattle Can Problems Restoration & Tools 5
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
C BN1 Clutch Pedal Rattle Austin Healey 2
B MGB-GT Need help with MGB GT rattle MG 0
S TR2/3/3A Rattle Triumph 9
S TR2/3/3A some rattle can primmer Triumph 9
warwick-steve Mystery Rattle Austin Healey 21
S TR2/3/3A Hood - Rattle Triumph 15
R TR2/3/3A Clutch rattle/clack-!957 TR-3 Triumph 10
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
T TR2/3/3A Rear shocks and rattle Triumph 5
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
PatGalvin TR2/3/3A Bonnet Prop Rod Rattle Triumph 20
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
vette A Rattle, no no it can't be. Austin Healey 8
B Door rattle Austin Healey 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
D XJ6 series III front end rattle Jaguar 5
D Rattle in the boot Spridgets 7
RickB "Finished" my rattle can paint job Spridgets 19
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
R Rattle that won't go away Spridgets 6
memphis Door Rattle Austin Healey 3
tri_carb_healey 3000, starter rattle? Austin Healey 14
RickB Rattle can advice please Spridgets 76
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
AngliaGT MGB-GT GT Shifter Rattle MG 4
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
cdsmith brake shoe rattle? Spridgets 10
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
jerrybny Dreaded Stick Shift Rattle Triumph 2
Moseso TR2/3/3A TR3 Bonnet Rattle Triumph 24
zimmy anti rattle spring and plunger Spridgets 21
I TR6 TR6 Shake, Rattle and Roll Triumph 18
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
tosoutherncars Rattle on startup - 1500 Triumph 5
B TR6 TR6 Disc Brake rattle Triumph 2
71tr Rattle Cans and Dependable Suppliers Triumph 14
sim Rattle limiter is gone Spridgets 6
