Fender Spear Potential Rattle
RDKeysor
Bronze
I find one of the chrome decorative "spears" on my car, the right front fender bit, is loose at the rear end, and a potential rattle. With the RF wheel off and looking up inside the fender, I see two round pieces perhaps 1/4" long that somehow attach the spear. I was tempted to remove the panel inside the wheel well to better reach that location, but decided it likely wouldn't come out without a lot of work. So, are these round pieces threaded, and can they be snugged up enough to eliminate the potential rattle? The spear on the other side of the car is snug
roscoe
I might be wrong but I think there are two styles out there. One has 2 plain welded on studs with no threads, similar to the air vent covers in the BN2 I have. These would be secured with press on stamped metal thngies that are concave slightly with tangs on the holes in then such that they grip the smooth studs and act as a clamp. The other style has threaded studs and takes nuts. Either way to tighten them you'd need to get to the back side unless you can wiggle into the small gap where tge spear doesnt quite cover the vent. In a pinch you could probably stop the wiggle with some clear silicone injected underneath. Clear packing tape won't get you any concourse points but it might kerp your spear from departing until you can fix it.
jimmyr
Member
The non threaded type are called Tinnerman clips in the US, and are either round or square. You will need a helper to hold the spear firm against the fender while you push the round fastener tight around the stud.
R
RDKeysor
Bronze
Thanks. That makes sense, but even with the wheel removed I found I couldn't reach the rear fitting. With someone holding it tight on the outside, as Jimmy recommends, I may be able to reach the fitting with a pry bar. As an alternative, I may end up putting a bit of a wedge under the "spear" to tighten it.
R
RDKeysor
Bronze
I definitely couldn't reach the fasteners. I had someone hold the spear against the fender while I levered against the fasteners to no avail. Ultimately I slipped a bit of plastic under the lower edge of the spear, snugging it. Thanks for the responses.
AUSMHLY
There is a product called dumb dumb, which I believe is rubber brutal. (Body shops use it). it's black and sticky, consistency like silly putty.
I used it behind the chrome finisher on the top of my BJ8 door to keep it in place.
It is plyable, never hardens. You might be able up push some up under the spear, then wipe away any that shows afterwards.
Pretty sure if you drove to an auto body shop, they would give you a little for free. About a nickels worth.
Good luck with the issue.
D fender spear Austin Healey 23
ccw283 GT6 GT6 fender flares Triumph 1
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
5 TR2/3/3A TR3 fender patch panel question Triumph 10
H TR4/4A Fender/Wing repair how to do Triumph 5
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
K TR2/3/3A TR3's without the fender mirrors........... Triumph 6
1 TR3 Fender spats sold on EBay. Triumph 5
K TR2/3/3A Passenger side fender mirror....... Triumph 13
BoyRacer Rubber Fender Buffers Austin Healey 2
vette MGB Rear Fender Dog Leg Patch Panel MG 3
M TR2/3/3A Front Inner Fender Doublers Triumph 2
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
Boink Fender seam annoyance... Spridgets 4
D TR2/3/3A rear fender bead Triumph 2
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R TR2/3/3A Not for the faint of heart: Fender Horror Show Triumph 46
D Wing Fender Fitment Question Austin Healey 6
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
L TR2/3/3A Scuttle / front fender attachment Triumph 9
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
DornTRoriginal TR2/3/3A Fender Bead Installation Triumph 10
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
S T-Series front fender MG 1
I Wanted 69 TR6 fender Triumph Classifieds 0
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
K TR2/3/3A TR3 Spats?...Fender Skirts. Triumph 3
R Fender bolts Austin Healey 10
aero3113 1956 100 BN2 Fender Beading Austin Healey 8
maxwedge5281 aluminum fender vents installation Austin Healey 14
Rut TR4/4A Fender beading mounting tabs Triumph 3
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
Rob Glasgow Help with fender bead Austin Healey 26
R TR2/3/3A Securing the front fender beads Triumph 11
O Need front driver's side fender 65 Midget Spridgets 0
T TR2/3/3A Is there a way to get more clearance between tires and back fender on TR3A? Triumph 10
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
B TR2/3/3A Rear Fender Part Triumph 3
DornTRoriginal TR2/3/3A Stone Guard and Fender Fitting Issues Triumph 6
S TR2/3/3A tr3 front fender Triumph 4
charleyf TR6 Plate on drivers side front inner fender Triumph 6
S TR2/3/3A door fender gap Triumph 14
S TR2/3/3A Patching the front fender Triumph 8
drooartz Seam sealer for fender beading? Spridgets 9
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
