aluminum fender vents installation
maxwedge5281
i just bought a set of aluminum fender vents that have never been mounted and were bought from austin healey spares. i do not intend to paint my car anytime soon. but i would like to at least "rough" them in for now. what is the preferred method for cutting the initial fender opening? cut the hole to the size of the vent outer frame? or cut the hole smaller and turn in a flange to mount the vent to? or some other method? can they be glued in? etc!. any advice is appreciated! oh, i do have aluminum fenders front and rear!
John Turney
1. Make sure you miss the inner fenders.
I have steel fenders and vents, but here's what I did for cutting: My vents have a flange on the outside edge. I used the inside edge as a template, and after many prayers, cut the holes to match the inner edges. I had to cut the vents to fit around the footwells and inner fender braces. That was the hardest part. Then I cleaned the metal and brazed the vent flanges to the inside of the fenders. Smoothed the openings and an touch of filler and done.
I think gluing should work with aluminum. I prefer the smooth look.
maxwedge5281
maxwedge5281
healey blue do you have any pics of your finished fender vents. and, did you bend the flanges around the corners or just on the most flat areas? the vents i bought do not have flanges and are already cut on the backside for clearance to brace and foot boxes.
Deleted member 19315
I would use a sheet metal nibbler to cut the wing once you've marked it, you can work very accurately with them and the distortion problems are very limited . Maybe have a flange water jet or lazer cut from aluminium to fit the vent you have.The flange would be welded to the vent then use car body adhesive or sikaflex polyurethane adhesive to bond the vent into place with the flange on the outside of the wing. It would look great in my opinion to supplement the adhesive bond with rivets around the flange. Dome heads are more traditional but pop rivets can work well if one takes the time to fill the heads before paint.
Its what I would do anyway....
vette
Hi Maxwedge, I think you and Healeyblue might be talking about two different kinds of flanges. From your original post I got the impression that you were talking about turning the cut edge inward to a 90 degree inner flange. With the tool that Healeyblue is talking about, that tool makes an impressioned OffSet flange. As you know turning the edge to a 90 degree flange is much more difficult to keep the panel smooth. I know you can do it but just one thought, The 90 degree flange would give the panel strength, but if you did not flange it, once the vent was installed i believe the panel would have good strength. I would cut the hole smaller and see how much the panel wants to waffle.
Jerry
type of glue to use. I have used new panel adhesive, the type used in many autobody shops, and I cannot pry it apart. I think it would work for this use.
healeyblue
Yes I was talking about an offset flange so the panel will fit flush. I do not have fender vents but have used this tool to make flush fitting panels.
John Turney
With no flange on either the vent or fender, you're looking at tig welding the edges together. I'm sure someone is that good, but not me. Alteratively, if you look at the first photo in Steve's article on fender vents, https://www.stevesaustinhealey.com/...rks-rally-side-vent&catid=2:projects&Itemid=3, it shows the factory installation. The opening in the fender is cut ~1/4" smaller than the vent and folded inward to form a flange. The vent is slipped around the flange. It looks like the original is riveted into place, but gluing would probably be neater.
Depends on the fender vent construction. Ones I installed on a car years ago had flanges so they were easy to spot weld on. Biggest thing at the time was locatiing it on the fender and then cutting a perfectly good fender. I did like the result.
Marv
HealeyRick
John,
Thanks for posting this. I was looking for Steve's website the other day and it was no longer being hosted at its old site. Glad to see that info is still out there. Lots of good stuff.
Setting the WayBack Machine to 1985, I installed a pair of "Layne's Louvres"; these were a little smaller than the actual works type, but are still pretty effective. They're contructed with an extruded aluminum frame, providing a "finished flange" on the outside of the fender (using this old pic for the obvious contrast, exploiting the use of gray primer where the paint cracked while rolling a flange inward).
Layne provided a template, but in essence, a 1" flange was turned inward on the three (3) straight sections of the louvre, and the three (3) corners were cut to just allow the vent to fit__the finished flange covering the cut.
The aluminum frames were thick enough to put a 1/4-20 tapped hole in the center of each straight run, with a bolt through the fender's flange and into the frames (3 per vent). Being removable, taking out the LH vent gives great access to the brake & clutch master cylinders, which is most welcome with a brace of sidedraft Webers restricting access from the top.
Showing a little bit closer detail of the exposed flange:
Try as I might, I don't have a picture of the flange from inside the fender readily available... :(
blueskies
Nice job, Randy. If I ever want to build a rally car and use those vents currently in storage, I hope that I can find your pictures.
Marvin Gruber A/H Right rear Aluminum Fender Austin Healey 0
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 1
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
T TR2/3/3A My after market aluminum side curtains won't stay in on front top! Triumph 6
tinman58 TR5/TR250 Aluminum oil galley plug Triumph 1
