TR6 Aluminum block engine
nichola
Bronze
I just found out I have one of only four aluminum engines made for the TR6! Check the attached picture. Can’t wait to finish the build.
Gliderman8
What year TR6 is that engine out of?
martx-5
Special alloy called rattle-can. :wink-new:
M_Pied_Lourd
Yeah, was going to says, April Fools...
Darrell_Walker
Here is the special aluminum wet liner block in my TR4A :smile:P7200005.jpg
M_Pied_Lourd
Rare Aluminum Block found in a swamp...
J DMD Aluminum block Austin Healey 6
PAUL161 215 Aluminum Block Buick MG 65
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 1
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
T TR2/3/3A My after market aluminum side curtains won't stay in on front top! Triumph 6
