TR5/TR250 Roto aluminum wheels on ebay
Got_All_4
Been eyeballing these wheels for some time now and been wondering how these would fit my TR250. They have them listed for TR6 but note that they are 7 inches in width with a 12mm off set and I think the 6" have a 3mm offset. Factory steel wheels have a 0 offset so the little extra offset is to keep them away from the fender? Also the 6" ones are $100+ cheaper. Don't understand that because there is more material in the wider ones so more machining too.
Mickey Richaud
I've seen those on ebay as well. But I got my LeMans wheels from Hap Waldrop, a member here. Not that much more in cost, and I felt more secure buying from him.
M_Pied_Lourd
FWIW, I have 16x7 Konig Rewinds on mine that have a 0 offset and they fit fine.
Cheers
Tush
Got_All_4
Got_All_4
I was asking because every time I get the $ saved up to purchase them then something happens and I need to spend the $s on a house item. Just happened again last week over 1k in water equipment. The 7" are always less dollars then the 6" for some reason. So if the kitty is almost full and the itch gets too strong I can opt for the 7"ers.
Tush what tyers are you running? Don't want to buy new treds too.
Mickey Richaud
M_Pied_Lourd
I'm running Yokohama Avid 205/60/16's
Cheers
Tush
Got_All_4
Got_All_4
I've got 205/70/15 Hancooks. I was concerned that I would need a wider tire or something. Thanks for the link however I didn't see the finish I wanted.
svtmikey Metalastic versus generic Roto-flex couplings Triumph 5
Tabcon The "Resto- Roto" in action! Triumph 11
V GT6 GT6 Metalastik roto couplings. Triumph 3
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 0
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
