TR6 Aluminum trim ring band removal
ichthos
I gave up trying to find NOS aluminum trim rings. To get the ones I have anodized again, I need to remove the metal ring on the inside that holds the ring to the wheel. Anyone know how to do this?
Kevin
Gliderman8
The trim ring is just held in place by some "spring fingers" around the circumference of the ring. You should be able to carefully lever it out with a rage between the ring and the wheel and use a pointed tip to start it coming up.
TR3driver
Great Pumpkin - R.I.P
I think he means how to get the "springy fingers" away from the trim ring. The spring part is steel and the anodizing process will attack (ruin) it.
I
ichthos
Yes, I was talking about the spring fingers. The process would eat the metal spring fingers, so unless I can figure out a way to remove them, prepping and reanodizing the trim rings is not an option. I am pretty sure I am out of luck at this point as it looks like the spring fingers are held in place by the aluminum being pressed in place over it. I thought someone might have a way to get these out or suggest someone who could.
Gliderman8
Sorry, I misunderstood the original post.
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
Griz Aluminum door trim Austin Healey 5
trotti Aluminum cockpit trim Austin Healey 0
C Aluminum sill trim BJ8 Austin Healey 3
L Aluminum door frame trim Austin Healey 5
Mio Aluminum windshield trim Spridgets 3
bighealeysource aluminum trim piece for 100-6 BN4 door seal Austin Healey 2
TR4 TR4/4A ??Replacement TR4 Aluminum Cockpit Surround Trim?? Triumph 9
J Where to buy aluminum door trim. Austin Healey 3
R Protecting Aluminum Body Trim Austin Healey 3
B Cockpit Aluminum Trim Moulding Austin Healey 9
Tullamore Aluminum Windshield Trim Spridgets 2
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 1
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
