aluminum trim piece for 100-6 BN4 door seal
bighealeysource
Bronze
Question concerning the aluminum trim piece referred to as
the "cap, door seal" -sits at the top edge of the door and
is meant to cover the end of the door seal by the top frame
post attaching hole. Know that's all a mouthful but trying
to figure out if this is supposed to attach to a small
wood block or what as if I use it as intended, the majority
just hangs out over the door seal and has no place to attach. I have tried to come up with a photo and the best
one I have found is from the 100-6 calender put out by the
Austin Healey Club this year. Anyone know how it is supposed to attach ? Thanks,Mike (Big Healey Source)
bighly
There is a small wooden block, covered in upolstery with one screw down the center holding it in place. The aluminium finisher piece attaches to the wooden block and the furflex top end is held in place by the finisher.
bighealeysource
bighealeysource
Bronze
Thanks Bighly - that makes perfect sense and will sure
finish that area off nicely !
Regards,
Mike
I TR6 Aluminum trim ring band removal Triumph 5
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
Griz Aluminum door trim Austin Healey 5
trotti Aluminum cockpit trim Austin Healey 0
C Aluminum sill trim BJ8 Austin Healey 3
L Aluminum door frame trim Austin Healey 5
Mio Aluminum windshield trim Spridgets 3
TR4 TR4/4A ??Replacement TR4 Aluminum Cockpit Surround Trim?? Triumph 9
J Where to buy aluminum door trim. Austin Healey 3
R Protecting Aluminum Body Trim Austin Healey 3
B Cockpit Aluminum Trim Moulding Austin Healey 9
Tullamore Aluminum Windshield Trim Spridgets 2
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 0
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 0
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
