TR6 TR6 Disc Brake rattle
bailee2
The calipers, pads, lines, master cylinder, and drilled/slotted rotors are all new.
Problem:
I bought a shim kit at Roadster Factory to help with the front brake noise but came without instructions.
There are four shims. How do they mount and do they require sealant on the backside etc.
The brake noise is evident at almost all speeds and sounds probably worse than what it is.
Brakes work well with the exception of the noise.
Thanks.
:cheers:
Brosky
They go on the back of the pads between the pad metal and the piston. You can buy some products to add to them at any local auto parts store that will help secure them.
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
T TR6 tr6 rear disc brakes Triumph 30
A TR6 Clutch Disc---which way?? tr6 Triumph 12
milemarker60 TR6 My Rear Disc Brakes on the TR6/M3 Triumph 0
Brosky TR6 4 Wheel Disc Brakes for TR6 - Available? Triumph 17
G TR6 How thick should a clutch disc be? [TR6] Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engineā€¦ Triumph 7
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ā€˜74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ā€˜74 TR6 original radio Triumph Classifieds 0
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
