TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or
Hamish Racing
I have an early tr6 A type od gearbox.
Initially I had the TR3a clutch as the previous owner had it set up on a lightened original flywheel.
After some gearbox work the gearbox man re drilled and tapped the flywheel to take the later diaphragm clutch on the basis it’s designed to take more power and slightly lighter action. ( the mountings are different)
I think the later clutches are cheat too I think.
All the hydraulics remained the same.
malbaby
Has been a long while since I fitted a J type OD gearbox to my TR4. From memory it was an easy fit using a new clutch and pressure plate from the 6cyl gearbox, and the TR4 flywheel which I lightened.
M_Pied_Lourd
I used the TR6 Clutch.
Cheers
Tush
CJD
If my memory serves, you must match the front box nose to the clutch you use. The TR3 with fingers used a longer nose, while the later boxes had a shorter nose to clear the clutch diaphragm.
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
Brinkerhoff TR6 TR6 OD gearbox installed in TR3 ? Triumph 11
T TR6 TR6 gearbox into a TR3 - what should I know? Triumph 9
B Wanted Late TR6 Gearbox frame Crossmember Triumph Classifieds 1
K TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover? Triumph 2
W TR6 TR6 gearbox fluid? Triumph 14
W TR6 Gearbox fill-TR6 Triumph 5
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
mrv8q TR6 TR6 Gearbox cover TRF Kit Triumph 6
mrv8q TR6 TR6 Rear gearbox mount replacement Triumph 9
J TR6 tr6 gearbox numbers Triumph 4
I TR6 TR6 gearbox cover leak Triumph 5
F TR6 Advice on TR6 gearbox and rear axle fluids.., Triumph 7
SpannerMan TR6 New member intro and TR6 gearbox leak question Triumph 9
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
