TR6 TR6 Rear Hub question, plus gearbox vibe
Pete_Chadwell
Hi folks.
I have two problems with my 1973 TR6. First, a few weeks ago I had it up in the air to catch up on some long-overdue maintenance. While I was at it, and before I removed the wheels, I tried to "wiggle" the rear wheels to check the hubs. I've owned this car for 25 years and I've only changed ONE of the hubs, the right rear, and that was more than 20 years ago. (in my 25 years of ownership, I haven't added more than about 60,000 miles to the car) Anyway, the right rear felt solid, but the left rear--the one I've never changed--feels like it's got some play. Not much, but I couldn't feel ANY on the right side and I did feel a little slop on the left. At this point, I know I'm going to have to change that hub in the near future. I'd like to get some kind of frame of reference for knowing just how urgent this is. I know that a hub failure can cause the wheel to leave the car. For some reason I'm not anxious to experience that. Any thoughts? Keep in mind that I put fewer than 500 miles (and that's being VERY generous) on this car every year… so it's not like I'm out driving it all the time)
Second thing is a vibration I've noticed--it comes and goes--in the gear lever. I've been aware of it for maybe 3 or 4 years. This is a 'box that I rebuilt myself about 12 years ago. For a long time I've thought the vibration was the pilot bushing (which I replace at every opportunity) because the "buzz" only seemed to happen when I was in neutral. But now I'm noticing it more frequently when I'm in a forward gear, car in motion, either under power or decelerating. It comes and goes, it's either ON or OFF, and it's pretty "light". I can feel it in the gear lever and hear it when it happens, but it's minor enough that an untrained ear would probably not hear it. Any thoughts on that?
Thanks much!
Jims71TR
not sure about the gear issue but I would replace the lf hub and drive it for another 25 yrs..
poolboy
There will be a complete hub and axle coming up for eBay auction Sunday night around 7;30 pm pacific time.
It's mine.
TR3driver
Great Pumpkin - R.I.P
Assuming the bearings are what is loose, I'd say the issue isn't really urgent until you're having trouble with the brakes rubbing or hearing noises from the bearing. That's not the same failure that causes the wheel to leave the car. Some people have even reported success just tightening up the adjustment nuts a bit.
When you do change it, you might want to consider the stronger hubs from Goodparts.
Triumph had a lot of issues with the shift lever rattling over the years. One possible cure is to add a brace (if it is not there already) from the bolt on the side down to one of the tail housing bolts. There was also an early service bulletin on the topic, that I can't seem to lay my hands on at the moment. But here's a thread with the text from the TSB:
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/524587
hondo402000
I replaced my rear axles with Goodparts CV axles, I would be willing to part with my old ones, they are in good shape no play. if you are interested send me a PM
Hondo
Pete_Chadwell
Pete_Chadwell
Thanks, everyone. I like the Goodparts option, and I'd love to go the CV jointed route, but that's some real money there. I see he's got hubs that'll replace the stock hubs on the stock axles, so I will probably have to go that route. But then that means that going to CVs later would require me to throw away (sell) the Goodparts hubs. So, I'd REALLY like to do the CV axles and hubs all at once and be done with it.
How do you like the CV axles?
Thanks again!
hondo402000
so far I really like mine, no more TR Twitch, also if you do the axles check your hub studs and do the repair if you have them out
Hondo
sail
Another one here who went with Goodparts hubs for peace of mind. $'s stopped me there except for new U joints.
Oh yea, do the studs.
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
SCguy TR6 Rear Hub on a TR6 5 out of 6 studs enough? Triumph 24
G TR6 TR6 Rear Axle and Hub - saga continues Triumph 7
tr6web TR6 Rear hub u-joints TR6 Triumph 9
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
