TR2/3/3A Problem with the gear lever "anti rattle fix".....
karls59tr
Bronze
I installed a 5/8" x 7/8" hard rubber insert on the gear lever to stop the annoying rattle when shifting. Well there is no rattle noise now but it is extremely hard to get the shifter in reverse? Anyone else done this modification and have the same problem? What do you suppose is the causing the balky reverse shift?
bobhustead
Tinkering is often not a great idea. Our cars were marginal as designed. The gear lever needs to move up a bit to get into reverse. If it can't move up properly, no reverse. You should stop tinkering.
Bob
K
karls59tr
Bronze
Bob
This fix was recommended by Triumph to solve a problem common to TR3's.
Fern
Tinkering is the mother of all inventions….or is that …eh necessity…at least now I know why my shifter rattles. :smile:
K
karls59tr
Bronze
Frank Zappa was in the Mothers of Invention and he tinkered with every musical format.....and now back to my question.:cool:
mgedit
Found the same thing. I reduced the length of the insert and it is better, but still a little difficult to get into reverse. One of these days I may take the rubber piece out. I used a short piece of fuel line. Cheers, Mike
Graham H
The length of the rubber hose is stopping you from lifting the shifter to engage reverse try cutting small amounts off until it gets easier. I found with the TR6 box the shifter gate has a sloped entry for the reverse position so you don't have to lift the stick, so you could modify it and solve the problem.
Graham
K
karls59tr
Bronze
Graham
I do have a TR6 box in my 3. I did not know that about the sloped entry. I had put a piece of hard rubber bushing in as the spacer but I don' think it had enough "give" to it so I'm going to use rubber hose this time. I think part of the problem is that the little plunger at the very bottom of the lever was quite worn down. I reversed the plunger, as the other side of the face it still had a flat surface, but don't think that helped. I'm going to order a new plunger and spring.
Karl
Graham H
I found the new spring was too long and wouldn't compress enough to get the plunger in so had to cut some off.
Graham
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
Got_All_4 General TR Problem mounting the a type to the gear box Triumph 12
tahoe healey big gear box problem Austin Healey 7
J 1st gear problem, jumps out Austin Healey 13
Tim Hollister Rib Case Trans Problem - 1st Gear Spridgets 6
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
D Acceleration Problem Austin Healey 4
