Europa turn signal problem
Mike Stobbe
Is there anyone who can help me with a turn signal problem? My turn signals work, but so rapidly that it's better described as a "flicker". I've had all four lights out and apart, but the turn signal relay box is still original and undisturbed, so it's probably something that I've done at the four corners, and not the relay box. I've also heard that these relay boxes are NLS.
equiprx
Rapid flashing is probably a dead or dying flasher unit.
Usually some form of 'tin can' in the circuit.
Any replacement with similar amp rating and connections should do.
Platinum
Check and clean the ground wire connections, both at each of the light bezels and all the chassis points! If it's all four corners I'm betting there's a bad ground at the chassis.
M
Mike Stobbe
Thank you for your input. I think I've fixed the problem. I couldn't find fault with the grounds, and there was nothing to be done if the problem was within the flasher relay unit (except replacement), so I took a close look at the bulbs: common 1157 twin filiment bulbs of 32 watts for the turn signal. The service manual specifications call for 21 watts; not a common size but my auto parts store was able to special order them: #7528 bulbs. Changing all four bulbs slowed the flashing rate significantly. This makes sense: the 1157 bulbs were putting a bigger load on the resistance coil heating the bimetallic strip. This causes the bimetallic strip to heat up faster, opening the points faster, tripping the relay. The 7528 bulbs reduced this load, slowing down the cycle.
Platinum
I guess that's reasonable but I've not had the same issue with 1157 bulbs for decades. It sounds as if the flasher has gone limp. Which Europa? Renault or T/C? All the plastic cars I've owned or serviced have had a "standard" flasher relay, the three-prong can, grounded with the casing.
M
Mike Stobbe
This is a '73 TC car. The flasher relay unit is a black box, actually a steel rectangular box with 8 leads attached. I've been told they are NLS, but I haven't persued a replacement so I don't know if that's true or not. It includes both the turn signals as well as the hazard flashers. Took it on a tour today with the local British Car Club. All went well.
Roger
Bronze
The relay unit box doesn't contain the flashers though. It controls the switching of the brake lights to indicators and back again.
There are 2 flashers, one for indicators and the other for hazards.
Lotuswins For Sale 87 Esprit Turbo and 72 Europa Racer Other British Classifieds 1
M Lotus Europa Spiral Pins Lotus 9
B Anyone have a Europa Twin Cam for sale? Lotus 6
Grantura_MKI Europa at auction. Lotus 6
glemon Europa S2 Lotus 2
X Help me celebrate my Europa's 40th birthday! Lotus 1
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
Bob Claffie Europa Project Lotus 1
K Heigt of a Lotus Europa? Lotus 5
D Europa a la Foose Lotus 10
D For sale Daytona Europa Lotus 1
jjbunn Lotus Europa - what to look for? Lotus 12
aeronca65t Europa Spotted 13
H Boy do I love it when things work....Becker Europa Austin Healey 16
Reh Lotus Europa Wheels Triumph 3
Roger My '72 Europa Lotus 27
JodyFKerr Europa Technical and Parts information Lotus 6
RobT Europa 47 GKN Sighting Lotus 3
P Racing Europa Lotus 2
M europa,wider,lower,tires,wheels Lotus 0
Roger Europa TC Brakes Lotus 5
Roger My Elise has company - '72 Europa Lotus 9
D Saw a nice Europa today--one of you guys? Lotus 6
R6MGS Europa grills Lotus 15
R6MGS Europa with Mazda Rotary engine Lotus 69
C Europa Twin Cam Autocross Car Lotus 3
walt Help identify renault engine in 71 S2 europa Lotus 1
RobT Europa Up-date Lotus 8
RobT Europa "Basket Case" Question Lotus 6
RobT Thinking of buying a Lotus Europa S2... Am I nuts? Lotus 9
RobT Thinking about a Lotus Europa S2... Am I nuts!! Triumph 24
LeeMcKee Looking for a Europa air dam Lotus 0
JamesWilson Europa- Buying Guidelines wanted Lotus 19
Y Cross Reference on Brakes for Europa Lotus 2
78Z New Europa - not for North America though Lotus 9
Y Restarting a stored Europa issues Part #2 Lotus 0
Y Restarting a stored Europa issues Lotus 1
Y Jacking points and jack stand placement on Europa Lotus 1
Y Europa Towing Points Lotus 2
Y Thinking of a Europa for my next car Lotus 2
G My 1969 Lotus Europa S2 is FOR SALE! Lotus 0
CraigFL 220HP Europa??? Lotus 7
J Lotus Europa for sale..What do U think? Lotus 19
Roger Lotus Europa for sale Lotus 4
G Voltage Regulator - Europa S2 Lotus 2
G 2 Weber 45's; nice Europa new resto . for sale Lotus 0
Carlbanan56 MGB Mgb turn signals MG 17
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
