Europa "Basket Case" Question
RobT
Per my earlier post I have been pondering a Europa. Well there is one near to me that may be for sale but is probably a basket case.
I think there is a sad story behind the car, but it looks to be an unmolested late model twin cam. Its all there but has not run for 4 years, and sat out side exposed to the New England elements all that time. I was not able to get into the car, or lift the rear hatch. The window seals are gone, and the interior looks a mushy mess.
One thing I also noticed was the doors did not fit properly. There was about a 1/2 inch gap near the top rear of both the drivers and passenger side doors. Could this be "sag" from a completely rusted chassis?
If I get to inspect the car (not even sure the owner wants to sell) what should I look at, or should I just run like heck?
TIA
Rob.
Steve
Platinum
I think that running might be a good response here. If I recall correctly, the Europa has a space frame that is bonded in to the body. I may be mistaken here, but there is something that is waving red flags like crazy, and I think that's it.
Dan_Morrison
Member
You should probably plan to rebuild or refurbish everything (and I mean just about everything) and unless it is a give-away price, it may not be worth your time and especially money. You should check out the chassis for rust in the front bulkhead. I'm not familiar with the climate in that area, but if they salt the roads during Winter and the car was driven during those times, the chassis will undoubtedly need to be replaced. The only chassis that was bonded in was the S1. Good luck.
Platinum
Sounds kinda bad. There may be a parts car there, as John says, but everything sounds compromised. The door sag is the least of the worries. Chassis is 18 Ga. mild steel and will likely be useless, the engine having sat exposed to "outdoor" conditions that long can't be trusted... brakes, bearings, seals... just watch that one and wait for one you can at least test drive. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Deleted member 3577
Does someone still make a tube frame for the Europa?
Sparkie
Yes there are frame makers out there (across the pond). Spyder has made replacement frames for years. They were real dorks when I purchased from them will never do business with them again!
I have all of the dimensions and many pictures of my buddies Spyder frame which I used as a pattern to begin with, then built one myself. The frame is actually very easy to build - all on a single plane. I'll share info if you'd like. If you go the double A arm route for the rear suspension, the old Banks Servive Station (now Europa Engineering) has a much better geometry than Spyder. Spyder's top A arms are far too short.
Richard Winter owns Europa Engineering - a great guy who's very sharing with his knowledge and very serious about his Europas.
https://www.spydercars.co.uk/ - just say NO...
https://www.banks-europa.co.uk/index.php I would recommend these guys hands down over Spyder. Great pictures!
Lotuswins For Sale 87 Esprit Turbo and 72 Europa Racer Other British Classifieds 1
M Europa turn signal problem Lotus 7
M Lotus Europa Spiral Pins Lotus 9
B Anyone have a Europa Twin Cam for sale? Lotus 6
Grantura_MKI Europa at auction. Lotus 6
glemon Europa S2 Lotus 2
X Help me celebrate my Europa's 40th birthday! Lotus 1
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
Bob Claffie Europa Project Lotus 1
K Heigt of a Lotus Europa? Lotus 5
D Europa a la Foose Lotus 10
D For sale Daytona Europa Lotus 1
jjbunn Lotus Europa - what to look for? Lotus 12
aeronca65t Europa Spotted 13
H Boy do I love it when things work....Becker Europa Austin Healey 16
Reh Lotus Europa Wheels Triumph 3
Roger My '72 Europa Lotus 27
JodyFKerr Europa Technical and Parts information Lotus 6
RobT Europa 47 GKN Sighting Lotus 3
P Racing Europa Lotus 2
M europa,wider,lower,tires,wheels Lotus 0
Roger Europa TC Brakes Lotus 5
Roger My Elise has company - '72 Europa Lotus 9
D Saw a nice Europa today--one of you guys? Lotus 6
R6MGS Europa grills Lotus 15
R6MGS Europa with Mazda Rotary engine Lotus 69
C Europa Twin Cam Autocross Car Lotus 3
walt Help identify renault engine in 71 S2 europa Lotus 1
RobT Europa Up-date Lotus 8
RobT Thinking of buying a Lotus Europa S2... Am I nuts? Lotus 9
RobT Thinking about a Lotus Europa S2... Am I nuts!! Triumph 24
LeeMcKee Looking for a Europa air dam Lotus 0
JamesWilson Europa- Buying Guidelines wanted Lotus 19
Y Cross Reference on Brakes for Europa Lotus 2
78Z New Europa - not for North America though Lotus 9
Y Restarting a stored Europa issues Part #2 Lotus 0
Y Restarting a stored Europa issues Lotus 1
Y Jacking points and jack stand placement on Europa Lotus 1
Y Europa Towing Points Lotus 2
Y Thinking of a Europa for my next car Lotus 2
G My 1969 Lotus Europa S2 is FOR SALE! Lotus 0
CraigFL 220HP Europa??? Lotus 7
J Lotus Europa for sale..What do U think? Lotus 19
Roger Lotus Europa for sale Lotus 4
G Voltage Regulator - Europa S2 Lotus 2
G 2 Weber 45's; nice Europa new resto . for sale Lotus 0
J TR2/3/3A Basket weave dash on TR3 ???? When Triumph 21
T Basket case BJ8 values Austin Healey 10
B TR2/3/3A 57 TR3 Newbie...No spark? Basket case Triumph 31
Z MGA MGA Basket Case Value? MG 9
