1977 MG Midget 1500 Problem
M
my77midget
I have a problem with my 1977 MG Midget 1500, and I'm really hoping someone out there has a solution for me. The car will run absolutely perfectly for about 40 minutes, then will studder, stagger, and attempt to die, and, eventually does. Today it just barely got me home. Once it happens, it gets progressively worse. This is the third time it has happened to me, and each time I think I have the problem solved, so I take it on my "test loop", which is about a 45-minute drive, and each of the last three times she has done the same thing. The first time it happened, a mechanic friend towed me back to his garage, and the electric fuel pump was dead. This fuel pump had been replaced over the original by a prior owner. My mechanic blew out the fuel lines, (I had already replaced the fuel tank with a new one, and did it properly) and he ran fuel pump tests. The pump was dead, no doubt about it, so we replaced it. Next day she ran perfect again, for about 40 minutes, then the same thing occurred. I was able to make it home. Did some online forums research (not this forum), and many people seemed to have had the same problem, and said to replace the distributer rotor with the high-quality red one from Moss Motors. I did that. So today, fairly confident I had it solved, did the "loop" again, and again, after about 40 minutes, she was loading up, stumbling, progressively got worse, but I managed to get home again. I know driving it when it's acting up will eventually hurt the car, so.....if anyone can help me, PLEASE!! I'm now thinking coil, electronic ignition, or something other electric. Or could it be fuel? I know these are the worst problems to track down, short of having a mechanic follow me in a truck full of diagnostic testers, etc....I'm fairly savvy on some things, but this one has me stumped! Thanks so much for any and all help! Jeff.
JPSmit
I had this happen (minus the fuel pump) and discovered that the issue was the intake manifold was a little bit loose - when I started it everything was fine but as the engine warmed up it expanded and created a gap - letting in more air - affecting the mixture and all of a sudden exactly what you describe. There is a very easy test. when it is running poorly take off the air filter and cover half the carb intake. If it pickes up with the air restricted this is likely your problem. Good luck and try the simple things first. Keep us posted.
M
my77midget
Hey John- Thanks very much! This is something I never would have thought of! I'm going to try this tomorrow morning, on "the loop"! I really appreciate you taking the time to help me out on this. I will keep you posted!
bobhustead
A bad coil or condenser will produce the symptoms you describe. Fuel is not likely. Another way to check intake manifold air leak is to rock the manifold while running. Position changes by a loose manifold will vary the running speed.
Bob
Bob
M
my77midget
Thanks so much guys, for your replies. John, the intake manifold was on tight, no leakage. So it wasn't that. Thanks again for the suggestion!
Bob, I appreciate your input. I'm in the process of ordering a new coil. This was my train of thought from the start, but my mechanic friend said it wouldn't be that. Once I get the new coil in, I'll update you all on the results. Even though so many bad thoughts are crossing my mind right now about dumping the car through the frustrations of the whole thing, I am determined to hang in there and find this problem!
Glovcol
After the loss of leaded fuel, I had a similar problem with my frogeye sprite which turned out to be the fuel heating up and causing a vapour lock which disappeared when the engine was turned off, but returned again soon after. I re routed the fuel line away from the carb heat shImelda and all has been well.
dave99
ZS 150 carb? Check the choke spring. Make sure it’s not broken and engaged. The ZS goes full choke if not set or the spring breaks.
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
T MGB-GT 1977 MG BGT electrical MG 6
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
J 1977 MG HELP!!! Fluid issue MG 7
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
