MGB 1977 MGB Brake issues
Celtic 77
Just recently picked up a 77 B (Number 6 over the years), looks very good, numerous new stuff, and a factory hardtop! Only problem is the brakes... Allegedly has new brakes, pads, drums. But very exciting to drive on the northern NJ highways getting it home. Probably has about 25% stopping power. Emergency brake is good. New Master cylinder. Thoughts? We're bringing it to a local Brit car guru on Monday. Lastly, is a brake booster really necessary? As I recall, effort was never an issue.
JPSmit
welcome - sounds like a great project. (assuming you don't die :ROFLMAO: )
Assuming you have a hard pedal, two thoughts.
1. How are the hoses? were they replaced? ordinarily a perished hose stop fluid flowing back so is more likely to have the brakes seize than not work, but, still worth checking.
2. Were the rear brakes adjusted properly? With new pads etc it is likely they didn't bother. You should be able to jack up the rear wheel, tighten the brums until they grab and then let them off till the wheel spins. On clue could be how far back you have to pull the emergency brake to make it work - too much and the rears for sure need to be adjusted.
good luck!
Joe Reed
Could easily be a faulty booster.....or the hose from the intake to the booster...
kilofoxtrotalpha
A servo isn't generally considered essential because the original braking system was over-engineered (like much of the rest of the MGB) and is much more than adequate. But a servo makes braking feel more like that in a modern car. Although it feels easier, it won't stop you any quicker. We fitted one to our 72 Roadster, and can recommend it. If you have 25% braking power, it's probably a fault in the hydraulics.
Celtic 77
Celtic 77
Thanks for the input.
Well, found the beginning of the issues...leaking rear wheel cylinder. Brakes definitely a necessity her in northern NJ. Future project includes dumping the CAT and eventually a "real" exhaust. Shame on us for not taking it for a test drive. But, after 5 previous MG's, who would've thought! Overall, though, the car looks good. Two small rust spots at bottom of front fenders. Patch panels next! The car came with a factory hardtop, new top, and solid floors with excellent interior.
Celtic 77
Celtic 77
FYI... Update on brakes. rear wheel cylinders replaced, rubber brake lines to caliper replaced. Steel lines cleaned out and guess what came out. Compacted 4" worm of rubber that apparently built up and compressed the bits of rubber until barely stopped the car. Next issue is excessively fast idle that started right after a 50 mile drive. CD 175 carb...Thoughts anyone?
Platinum
Which choke mechanism? I'd look to that first. Then the air bypass valve.
JPSmit
Before you start too much diagnosis, it took me an embarrasingly long time to realize that you need to set the idle with the engine hot. You might just want to adjust it and see what happens. If it is stuck however, check if the cable is binding before you go too far into the carb.
Platinum
Disconnect the cable from the carb and see if the thing drops to some reasonable RPM.
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
