MGB trying to locate the ignition relay on a 1977 mgb
aayjaay
having a problem locating the ignition relay on a 1977 mgb roadster. bought a new one, but don't know where it is located
There are two relays on the right inner wing of the engine compartment. They are identical.
I believe the forward-most relay is the ignition relay.
HTH
Guinn
I just had a problem where I needed to find the starter relay. By trial and error found it just where Rick said. YOur 77 should be the same as my 78.
Guinn
Platinum
Should it not be the one with a white/red trigger wire?
Kimberly
Not all '77s were fitted with ignition relays. If your car has an ignition relay, it will be located to the side of the fuse box. It looks like the starter relay with one exception, the starter relay has a white/red wire going to pin W1 and the ignition relay has a white wire going to pin W1. The way to tell if your car has an ignition relay is to look at the third fuse down. If the third fuse down on the fuse block has a white/brown wire connected to it, you have an ignition relay. If the third fuse has a white wire with no tracer color, you don't have an ignition relay.
If you don't have an ignition relay and want to install one, follow the wiring diagram for '78 and later at https://www.advanceautowire.com click on stock schematics.
M Trying to locate William Holden Racing 2
BrettSutherland Trying to locate BN1L152555 '54 Healey LeMans Austin Healey 6
BrettSutherland Trying to locate Austin Healey 9
77_MG_Midget Trying To Locate Parts Spridgets 3
D Trying to get back working on the 1974 Midget Spridgets 12
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Trying to understand my cooling system Austin Healey 29
D Lilly second time running... or trying Austin Healey 8
D T-Series Trying to find out an interior dimension MG 7
T Trying to find an accurate tyre pressure gauge Spridgets 24
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
tomshobby I am trying to find the past history of my Midget. Spridgets 3
M MGB trying to change rotors - dumb question MG 7
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
H AH 3000 Trying to find the right look Austin Healey 23
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
JPSmit trying to understand camshafts Spridgets 22
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
G Trying to Find T-Shirts Triumph 7
