Wedge An issue with trying to start my TR7
Got_All_4
Having an issue with trying to start my TR7. First it is fuel injected. What is happening is I have to crank it for a while. Stop and wait a few seconds and it usually starts on the next crank. It happened once last year and once early this spring but has been happening with more frequency. Friday I decided to drive it for work and I'm an outside sales rep and make about 10 customer visits a day. I had to crank it first thing in the morning and also after my first stop. It was fine the rest of the day though. Seems to me it's a fuel delivery problem but not sure. Don't know anything about the ignition system. Any Ideas?
trglory
Cold start injector is the first place to look. Also, check the intake duct for cracks or pinholes, especially where it is near the battery.
Got_All_4
Got_All_4
Didn't get a chance to look at anything this weekend but I did replace the cold start valve 2 years ago. Those intake hoses as I recall don't fit very well.
trglory
It's very important that those hoses are air tight. Any air entering the intake system after the air flow meter will upset the air/fuel ratio metered by the ECU and degrade the performance of your car. The fuel charge may not be rich enough to start a cold engine in spite of the added fuel supplied by the cold start injector.
Administrator
Boss
Hey Got_all_4 - Without boring you will all the details, it was brought to my attention that people were getting locked out of this web site (unable to reach my server) after visiting this thread. After some sleuthing I discovered that there was something about the title of this thread that was triggering one of my security rules (my server saw the title in people's browser address bar and mistakenly thought there was a database injection attack being attempted. I slightly re-wrote the title of your thread (eliminated the word "Having" and "PI" and that seemed to fix the issue. Now I just have to go figure out who all was blocked from the site from visiting this topic LOL! Sorry for any inconvenience.
Got_All_4
Got_All_4
Oh wow sorry about that Basil. Interesting that something that innocent as a topic title can trigger something like that. Not on hear enough anymore to understand that.
Administrator
Boss
No worries. It’s pretty unusual that a certain combination of words would trigger a security rule. Doesn’t happen very often
Got_All_4
Got_All_4
Well it happened again. Pull the 7 out for it's madden voyage this year. Started right up, let it idle for a while. Shut it down and waited for the wife to come home so we can go to dinner. Took 3 times of cranking to start. While out every time I went to start it it took a couple of times of cranking to get it going.
sp53
This might sound weird, but on my early- fi- Saabs the engines starts better on a full tank. After the first start up, and warm up, the car is fine.
Got_All_4
Got_All_4
I haven't had time to investigate the problem however now that the temp is up around here there is no problem on restarts. Been trying to brain storm this so what could that tell you?
P TR6 Horn issue 1974 TR6 Triumph 5
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
T 100 BN2 Possible Ignition Issue Austin Healey 10
B MGA Tach drive issue MG 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
J Issue with Reverse Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
B General MG Turn Signal Issue MG 1
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A Brake issue? Triumph 8
M TR6 Alternator Issue for 72 TR6 Triumph 7
A TR6 TR6 Distributor cap issue Triumph 4
EricJNewman MGB Weird Brake issue finally solved. MG 1
B Any issue with cutting this weld on the spring base plates? Spridgets 4
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
C TR2/3/3A Water pump issue Triumph 8
Guido36 Chassis Number Issue Austin Healey 11
mch979 1967 MGB GT bonnet issue MG 25
H T-Series Brake Issue MG 5
K TR2/3/3A Steering Issue? Triumph 23
P TR3B Coil Issue? Triumph 7
Lin Excellent Issue of the Marque Magazine Austin Healey 2
R TR6 Is this a starter issue? Triumph 6
M Lighting issue Austin Healey 3
B TR4/4A Thrust washer issue Triumph 11
jfarris Honda Parts Issue? Other Cars 1
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Heat-related carb issue on BN1 Austin Healey 7
M TR6 Starter lagging issue Triumph 2
M TR6 PDWA Issue Triumph 5
R Issue with odometer after repair Austin Healey 1
Michael Oritt Bulb holder issue Austin Healey 5
D TR4/4A rebound stop clearance issue Triumph 13
S BJ8 Overdrive Issue Austin Healey 7
Michael Oritt Brake issue Austin Healey 24
G MGB Starter and fuel issue MG 6
S BJ8 Overdrive issue Austin Healey 10
M Help with 60 Bugeye - major drivetrain issue... Spridgets 78
catfood Looking for suggestions - ignition issue Austin Healey 6
N Electrical issue. FORUM Navigation Questions 2
Lin Another trafficator issue Austin Healey 8
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
glemon General Tech Turn Signal Issue Triumph 12
Michael Oritt Speedometer drive issue Austin Healey 4
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
S TR2/3/3A Electrical Issue Triumph 40
F TR6 Frame Issue Triumph 11
