Lighting issue
mgtf328
My sidelights were converted to LED by a previous owner. I've just noticed however that when they are switched on and the indicator is activated the rear light on the same side as the flashing indicator blinks in sympathy with the indicator. The sidelight doesn't go off altogether just dims slightly and comes back on. This doesn't happen to the front side lights. Any suggestions what to look for would be appreciated.
AJ
Patrick67BJ8
AJ
Check ALL your grounds. Mine did the same.
M
mgtf328
Been chasing down bad grounding but haven't found one yet. Interestingly the front lights are LED but the rear lights are standard. Not sure where or what size resistor I should be looking for. Any additional info would be gratefully appreciated.
There's also a hazard warning system fitted and I've noticed that when I turn the left indicator on the light in hazard warning system switch flashes but it doesn't do it turning right so I guess the problem is in there somewhere.
AJ
C TR4/4A Interesting Lucas lighting issue??? Triumph 5
L Lighting/Ignition issue MG 6
P Lighting issue on my "under restoration BT7" Austin Healey 8
F TR6 Tachometer lighting Triumph 8
D Shop lighting suggestions. Restoration & Tools 8
Dnickels Spitfire Spitfire lighting issues Triumph 4
T Decreasing Intensity of LED Lighting Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
steveg Improved Instrument Lighting Austin Healey 2
B Lighting Switch Question Spridgets 4
KVH TR4/4A Lighting Switch Triumph 3
C TR4/4A left brake lamp not lighting TR4A Triumph 4
B Instrumentation Lighting Austin Healey 12
RAC68 Dash Lighting [cost and access of incandescent Bulbs] Austin Healey 37
DerekJ Lighting circuit - the smoke's escaped from the wires.! Austin Healey 12
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
Boggsy64 MGB Dash lighting question MG 4
I TR6 TR6 lighting questions Triumph 4
BN6_2197 Details on Lighting Switch Austin Healey 5
L BJ8 additional interior lighting Austin Healey 7
B dash lighting options Triumph 5
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
memphis Rear License Plate Lighting Austin Healey 2
I Bugeye lighting/electrical help Spridgets 17
I lighting problem help Spridgets 14
T MGB MGB Instrument Lighting MG 7
TimK Gauge lighting Austin Healey 7
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
K Gauge lighting Austin Healey 14
Atrus Additional Lighting [headlights] Spridgets 24
newmexTR3 lighting relay question Triumph 2
ModifiedBJ7 Rear License Plate & Lighting Austin Healey 3
angelfj1 TR2/3/3A TR-3A exterior lighting - best source Triumph 4
kyreb1862 MGB Hot Lighting Harness 77 MGB MG 4
D xjs heater conrol lighting Jaguar 2
delisaj Dashboard lighting Triumph 16
drooartz Pictures, and lighting questions Spridgets 1
K Dash lighting Austin Healey 2
A interior lighting-guages Austin Healey 8
I TR2/3/3A TR3A - Forward Lighting Triumph 6
R6MGS Lighting Jaguar 0
S Interior lighting Austin Healey 1
Joe Reed Garage lighting? Restoration & Tools 36
P TR6 Horn issue 1974 TR6 Triumph 5
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
T 100 BN2 Possible Ignition Issue Austin Healey 10
B MGA Tach drive issue MG 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
J Issue with Reverse Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
