TR6 Is this a starter issue?
Ribbs
I just got my gearbox back in my 1973 TR6 after installing a new Fidanza aluminum flywheel and Magic Clutch Kit from TRF. Everything bolted back up - went to start the engine, but the starter isn't turning it over. I pulled the starter and tried it away from the flywheel and I can hear the motor running (can't say anything about whether the pinion gear pops out as I couldn't see it well enough). When I try to start the car (with the starter bolted up) I can hear the solenoid click followed by a hum. If I had to guess, the hum doesn't sound like the starter motor turning over - more like it's locked up, but that's just a guess. The other bit of sleuthing I did was to pull the plugs and roll the car to ensure nothing was binding. While the plugs were out, I also tried to turn the engine over with the starter - thinking that it should be much easier for the starter to perform that way but I got the same click and hum sound with the plugs out. Weird that the starter worked fine when I began this project 10-months ago.
Madflyer
I am not going to think badly did the new flywheel also have the gear installed. Second what starter do you have OEM or newer gear reduction??? all gears should match up on either starter.
Madflyer
Madflyer
The book shows Flywheel with gear Fidanza So starter most likely Remove starter and test it on the ground or in vice to hold starter Even a battery charger is enough to test Madflyer
R
Ribbs
The Fidanza flywheel did come with the gear ring preinstalled. And the starter is definitely not a newer gear reduction style.
Madflyer
Some times as with OEM I had a bad Commutator bar ( dead Spot ) and if bearings are bad can draw starter arm to fields and not allow to turn. tHey can be rebuilt but for same price I installed new Geared My TR 6 is also 1973 and was org. to car Madflyer
M TR6 Starter lagging issue Triumph 2
G MGB Starter and fuel issue MG 6
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
K TR2/3/3A Starter issue resolved.... Triumph 0
J Starter issue TVR 3
B Bugeye Starter Issue & Pics of the Car Spridgets 8
J TR2/3/3A Sickly starter or timing issue on 1959 tr3a? Triumph 7
bugedd Starter issue?? Spridgets 35
F TR6 TR6 Hot Starter Issue Triumph 4
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
mooncat help in troubleshooting starter issue! MG 3
B TR6 TR6 Starter issue......SUPER!! Triumph 12
A Starter Issue Spridgets 6
johnrip Wedge tr7 starter issue Triumph 1
7 Starter Issue MG 5
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
