TR6 ‘74 TR6 Starter & Trans Cover
EWD
Hi folks,
2 Questions:
1. Starter - Have replaced the ignition switch and new gear reduction starter ( British Starters). Starter does not turn without a direct hot wire from the starter to the switch. Did a resistance check on the wire (red/white) from the starter to the relay and appears ok. I assume it’s the relay? How do you check the relay?
2. Anyone recognize these two parts? The smaller one ( in front) was on the right side of the trans cover towards the rear. It fit just under the old cover. It’s hard to see, but there are 2 raised screw tabs in front where the indents are located. The other one was laying in the car and has been cleaned and painted.
Thanks,
Will
Gliderman8
I believe the ‘74 had a safety interlock that prevented energizing the starter unless you were sitting in the seat with the seatbelt on.
The “safety” feature can be bypassed by adding a jumper wire at the round connector that plugs into the seatbelt warning buzzer under the passenger footwell.
I believe you can jumper pin #11 and pin #12 on the round connector.
Please check the schematics for ‘74 to confirm.
poolboy
This is the seatbelt module..It would be mounted about where the passenger's left knee would be his foot well.
There would be an electrical plug for the big round hole..a 12 pin socket...splice the white/red wire to the white orange wire if it hasn't already been done.
EWD
EWD
Morning guys,
Made the connection per Ken’s direction above. Won‘t start unless I bypass the relay with a direct wire from the
ignition to the starter. Is there a way to test the relay before ordering one? Something else that I’m missing?
Thanks,
Will
poolboy
You can pry the cover off and have a look...I have found the contact points within corroded and stuck...It cleaned up pretty good and worked for years thereafter.
If you want to start by checking the external wire connections just follow the schematic to see if current is flowing as it's suppose to...W/O in W/R out and everything in between, but I bet it's going to be what you find under the cover.
EWD
EWD
Thx. Ken. Just finished my second cup and headed out to take apart the relay. Have cleaned and painted exterior but did not take it apart. Boy, I hope this is it.
poolboy
Check those external connections first....there's a chance that current isn't even reaching the internals like the points and the circuit board.
mrv8q
I believe it's pins 12 and 13.
poolboy
There's only 12 pins, Kevin....it's 11 and 12, but since it's the wires that need splicing it's the w/o (12) and the w/r (11) it's best just to concentrate on the wires, not the pins
EWD
EWD
Morning! It’s a great day in Virginia.
For the moment, all is solved.
1. starter - connections 11 & 12 made on the alarm module Problem was at the relay. Previous owner had the car worked on and the connections were put back reversed on both the starter and horn relays. I took a photo before removing to clean/paint and replaced in the same order. With it still not starting, I again took the relays off, and verified the connection numbers stamped on the back of the relay to the wiring schematic and discovered the problem. Connected 11& 12 per Ken and finally got rid of the module that was driving everyone crazy.
2. Thanks Easyrider for the photos. Have the brace installed. My car doesn’t have overdrive, so I guess the smaller piece was a standard install on the line. Didn’t know that the speedo angle drive was on the passenger side.
Thanks again guys. Getting closer and closer.
Will
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M TR6 Starter Relay on a 73 TR6?? Triumph 22
J TR6 72 TR6 starter problem Triumph 10
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
T TR6 TR6 Starter problem Triumph 8
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
B TR6 Hi Torque starter wiring - '76 TR6 Triumph 3
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
S TR6 TR6 Starter/solenoid Clicking Triumph 1
F TR6 TR6 Hot Starter Issue Triumph 4
DNK TR6 TRF TR6 Starter Triumph 20
O TR6 1971 TR6 Starter Help Triumph 1
Tr4dude TR6 Tr6 starter solenoid Triumph 4
TR6oldtimer TR6 TR6 Starter motor chatter Triumph 7
AngliaGT TR6 TR6 - Starter Problem Triumph 14
I TR6 TR6 - the perfect conversation starter Triumph 6
B TR6 TR6 Starter issue......SUPER!! Triumph 12
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Dotanukie TR6 TR6 Starter Question Triumph 18
TR6oldtimer TR6 '73 TR6 starter nearly done Triumph 3
TR6oldtimer MGB MGB starter and a TR6 MG 1
TRnorwegian TR6 Japanes TR6 starter engine - good idea or bad? Triumph 21
T TR6 Best source for a TR6 high torque starter? Triumph 12
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
2wrench TR6 TR6 Starter installed and working -- Thanks. Triumph 0
2wrench TR6 Help with TR6 starter installation. Triumph 19
C TR6 Starter removal help. 73 TR6 Triumph 1
hondo402000 TR6 TR6 New Starter on order Triumph 0
hondo402000 TR6 starter Problem TR6 Triumph 6
R_Lyle TR6 TR6 Starter wiring Triumph 11
D TR6 Hot wire [starter switch] for a 1972 TR6 Triumph 6
M TR6 TR6 Starter problem? Triumph 10
jimbar TR6 TR6 starter issues.. Triumph 3
S TR6 TR6 Starter install wiring--Help! Triumph 3
S TR6 TR6 Starter Replacement Tips Triumph 3
S TR6 tr6 Starter [again] Triumph 2
S TR6 TR6 Starter motor question? Triumph 3
Webb Sledge TR6 Starter & Clutch Problem [72 TR6] Triumph 14
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
