TR2/3/3A Early TR3 starter (bomb style) bushings sizes
Adrio
I was wondering if anyone knows what the sizes are for the two bushings in the TR3 (bomb style) starter motor. Mine are both worn and need to be replaced. I am hoping I could source them locally from a bearing place if I just told them the ID, OD, and length specs. Just trying to get back on the road faster (summer is short up here). Anyone know those specs?
Thanks.
Adrio
Frank Canale
BUSHING-CE--LU-M45G-M418G_p_303214.html
This might get you started. You will need to know exactly which starter model you have and take some measurements of the old bushings to confirm the dimensions. Looks like lots of N O S parts for lucas starters on eBay. Frank
TRopic6
Thanks.
Adrio
Hi Adrio,
I recently looked up starter & gen bushing numbers in a Lucas 400 catalog (downloaded from online) and remembered there was section that provides that info. I copied that info and pasted it below:
Lucas Bushes for TR2/3 starter 25541 (enclosed nose)
PN Starter ID OD Length
255491 M45G and M418G .626 .752 .750 (rear)
256112 M45G and M418G .566 .502 .687 (front)
Later TR3/TR4 25550 (open drive)
270038 M45G and M418G .877 1.003 1.328 (front)
- Rear bush is same
I've got that project ahead as well. Here's hoping we don't need to re-wrap the field coils - Have fun!
Jeff
A
Adrio
Thanks for the replies folks, they got me what I needed. Here is an update on my project.
I was able to source a rear bushing locally using the sizes you provided in your reply, thanks for that. That was the only one that was actually worn out (and it was worn out badly). The local part number (in case anyone needs one in a rush) was SS2024-12 Oilite 5/8 x 3/4 x 3/4.
My starter tested out fine electrically as per the tests in the manual and the brushes were long enough, so I replaced the worn bushing, dressed up the commutator, cleaned everything and then reassembled the starter. Once back in the car that starter worked better than it ever has in the 35 years I have been driving this car. My guess is that the worn bushing allowed the rotor inside the motor to rub against the cores of the field coils and the mechanical friction slowed the motor a touch until it eventually became noticeable.
Anyhow, the car starts instantly now, even when the engine is very hot.
Thanks for the help on this.
Adrio
mctriumph
Any working "bullnose" starter is a unicorn. 99% of these have failed when the drive coupling comes apart.
Put it under the bench for your children to find when you're gone. Install a new gear drive unit and embrace
the upgrade.I have push started more early Tr's due to this failure than I can count.
Did a concourse Tr2 some years back and spent a lot of time re-furbishing the OE starter. It rewarded me
by failing in 2 weeks when the afore mentioned coupling failed......
MD(mad dog)
sp53
Adrio did you find any pinion gears for the bullnose starter in your search for parts? I should have grabbed that one on eBay.
Thanks steve
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
M TR2/3/3A Rebuild early bomb style starter TR3 Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R For Sale 1956 Early small mouth TR3 Triumph Classifieds 1
R TR2/3/3A Early TR3 electrical system Triumph 12
jfarris TR2/3/3A Uh Oh - will these carbs work on an early TR3 Triumph 4
jfarris TR2/3/3A Installing replica Brooklands Areoscreens on early TR3 Triumph 4
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
M TR2/3/3A Which frame is correct for early TR3 Triumph 18
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
M TR2/3/3A Who sells seal for early TR3 hardtop? Triumph 6
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A Early TR3/4 trans help needed Triumph 7
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
