Pre-War Is it too early to write Santa? 1933 MG J1
JPSmit
Administrator
Boss
Oh mommy! That is gorgeous (and VERY tempting). JP, if ya don't mind, I'm going to move this to the MG forum but I'll leave a permanent marker/ pointer in the Pub. Lot's of MG guys who may not frequent the Pub would probably want to see this.
drooartz
It's never too early. What a lovely little car!
JPSmit
JPSmit
lovely indeed and no worries moving it boss
Grantura_MKI
I do favor J2s with wings, but the four place isnโ€™t what people covet. Nice example in lovely colours.
Administrator
Boss
Someone commented on one of the sites that you'd need a calendar to measure 0-to-60 (But you'd still have fun!)
JPSmit
JPSmit
I drive a Midget - and plan to restore a Multipla 600 followed by an Austin 7. what exactly is your point? ๐Ÿ˜
JPSmit
JPSmit
I think the trick is to have vehicles that tick all the boxes. I have a go fast and slow in the garage.
True - and the Vauxhall ticks that box. While I do wish I had a car that was better suited to longer distance cruising, I must confess I REALLY love the ability to thrash the Midget and never exceed the speed limit.
jlaird
Sigh, I am too old to thrash anything. However I got Bee running with a new carb last evening. Whee. then discovered that it got hot quick. Fan was not turning. Gish got to use heaver gage wire than that. Then found that other fan was running backwards, Fixed it.
Told you there was lots of stuff to do. Still have not driven it. Need to figure how to attach the downshift cable to the carb. Old carb had a piece welded on it for attachment and I have yet to find a female spade connector large enough for the electric choke connection.
Guess I need to visit the Chevrolet dealer.
Surely hope there is more to report tomorrow morning.
Mickey Richaud
Does this help, Jack?
jlaird
Ya but only I am old enough to remember pre war, just a we bit. Sorry. Do remember WWII quite well.
I am still learning this new forum, sorry for screw up. I would move it but think I do not nor ever have permissions needed nor want it..
PATR8 Too early for this stuff Triumph 13
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problemโ€”the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
K Too lean? Austin Healey 2
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
Marla TR4/4A Carbs too lean? Triumph 11
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
3798j Boomers Too Old for Sports Cars Other Cars 8
PC Dang, that was too good to be true... Restoration & Tools 3
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
A rear brake drum too tight after rebuild Austin Healey 3
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull Air Compressors, how much is too much? Restoration & Tools 7
Trevor Jessie Waaaay too much body roll Spridgets 14
Rut MGB Too many cars MG 31
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
KVH General TR How Tall is Too Tall for the TR4? Triumph 3
E Spitfire How tall is too tall? Triumph 21
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
