General TR How Tall is Too Tall for the TR4?
KVH
Is 6'4" pushing it for comfort in a TR4? I can't recall how far the seats go back or if the steering wheel hits the knees too easily.
And, BTW, I'm asking for a friend. I have no illusions about my own stature.
I am 6'5". I did put in a smaller diameter steering wheel, and lowered the foam on the drivers seat a bit. I can drive it with the top up if necessary, although my head rubs the convertible top. I have a long torso. Anyway, it works for me.
6'5" here also with longer legs. I had no issues with headroom, but trick was to slide your right leg under the steering wheel getting in and out. :smile:
This was a stock TR4A with original seats and steering wheel.
Scott
At 6'3" I made a few modifications. First I use TR6 seats. Then I modified the seat slider to go further back than normal. I use a 14" steering wheel. I have two TR4's and the last modification was to grind off the top corners of the dash support/ radio bracket. This I found dug into my knee. By cutting it back to a smooth inward curve I got clearance for my leg.
I note that I found the dash support on the TR4A a real pain.
Charley
E Spitfire How tall is too tall? Triumph 21
KVH TR4/4A What is "Too Tall" for a TR4? Triumph 17
cbrvfr You have to be this tall to go on this ride. Austin Healey 6
RickB Tricks removing old tenax fasteners? Need 4 tall.. Spridgets 11
V Tall guys and Spidgets Spridgets 5
mgbmedic MGB any tall mgb owners MG 15
drooartz Spitfire 6 foot tall in an early spitfire? Triumph 18
huck6 Mini for Tall Drivers? British Motor Corp 8
W Any tall Elan owners out there? Lotus 6
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
K Too lean? Austin Healey 2
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
Marla TR4/4A Carbs too lean? Triumph 11
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
3798j Boomers Too Old for Sports Cars Other Cars 8
PC Dang, that was too good to be true... Restoration & Tools 3
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
A rear brake drum too tight after rebuild Austin Healey 3
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
