TR4/4A Exhaust a tad too loud...
James A Martin
I have a TR3B that has a TR4 engine in which I installed slightly larger pistons. The exhaust system is just slightly too loud. Neighbors and I would prefer slightly softer too loud enough...slightly, slightly...
I was thinking about a motorcycle baffle in the end of the exhaust pipe.
Anyone tried this?
Comments?
Hamish Racing
Find your own supplier (this one for illustration only)
But I have something like this in my tool box when I do my sprints and hill climbs in case the venue noise police start to get twitchy.
luckily not needed as I hit 98dB which is ok in the uk tracks.
You can also wrap it with exhaust material if needed a good temporary fix.
If you need a permanent fix talk to a good exhaust shop about repacking you’re silencer box.
remember you may ? Have to revisit your carb settings to check on AFR.
jfarris
James, my 56 TR3 has the old standard straight thru muffler and a two outlet finisher that is not a muffler. I put a bike baffle at the beginning of the finisher and it helped just enough to make it tolerable. Drill one small hole and bolt in the bugle shaped piece, couldn’t be easier. They come in various shapes and sizes. If I remember correctly, under $15.
Good luck!
Rick_Thompson
I am in the same situation. 89mm pistons, "D" cam, tubular headers that have a 2.5" collector and a straight pipe back to a 12" square Flowmaster. Straight pipe to a blue colored 2" tailpipe. When trying to source an insert, it looks like the motorcycle ones are the only ones to fit. I have also seen fiberglass packing fitted to one tailpipe that looked a little cheesy. It would be good to hear what you end up doing.
mctriumph
Back in the day we would use stainless steel scrub pads.Worked and lasted OK. They
seemed to add a little bit of back pressure ,but not much. This was just the trick on
my old honda which had megaphone exhaust pipes,Got a lot of tickets!
Mad dog
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
