TR6 76 TR6 Brakes too tight
M
Mapickett
I replaced the wheel cylinders, brake shoes, brake hoses, and all new hardware on my 76 TR6. But even adjusted all the way loose I am unable to turn the wheels by hand. I loosened the screws that hold the brake drums on and I can then turn the wheels. I have had the drums off multiple times but I don't see anything wrong. All parts from Moss Motors.
Any ideas?
Gliderman8
There is a small adjusting screw for the wheel cylinder on the back of the wheel. It’s about 1/4” square and adjusts the brake shoes. I tighten the screw until I can’t rotate the wheel, then back the screw out so wheel rotates.
Gliderman8
Almost forgot….. Welcome to the British Car Forum!
Sarastro
Try what Elliot suggests--that may well solve the problem.
If not...it's common for the brake shoes made these days not to fit well. If you can't get them right with adjustment, you may have to file a little off the ends that fit into the adjuster. BE CAREFUL--there isn't a lot of room between too tight and too loose.
sp53
I found the same problem with the tr3. New stuff today is thicker. If you have the e-brake off and the adjuster back all the way plus you can get the drum on then put the tire on for more leverage. Now see if you can turn the tire and drum. If you can, then turn the tire around by hand a few times to see how much drag. Sometimes the newness falls off that way plus sometimes pushing on brake pedal with the drum and tire on will align the shoes. If not, sand some off like Sarastro suggested.
Steve
M
Mapickett
the brake drums turn less freely when the screws that secure them are tight. I think the shoes may be too wide.
M
Mapickett
I replaced the moss brake shoes that were too wide with a set from the TRF. All new springs, clips, and cylinders. When initially set up the wheels spin. But then after applying the brakes they do not release. Any ideas?
poolboy
Check the leading and trailing shoes..
If you are unsure of what I'm referring to, see the illustration in the Haynes manual and notice the space left on the shoes by the lining and that as related to the direction of drum rotation...that shows you what I'm talking about.
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
A TR6 '74 TR6 no brakes Triumph 14
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Z TR6 Can't seem to bleed TR6 brakes Triumph 10
L TR6 Help needed with TR6 Spongy brakes [sometimes] Triumph 24
S TR6 TR6 super excelent brakes. Triumph 3
bigbadbluetr6 TR6 TR6 Brakes Problem Triumph 18
C TR6 ? about TR6 brakes Triumph 13
T TR6 tr6 rear disc brakes Triumph 30
Brosky TR6 Could this be our answer for TR6 rear brakes? Triumph 24
N TR6 Clip wires on front brakes for TR6 Triumph 9
mlarnoldTR6 TR6 TR6 brakes failing Triumph 12
T TR6 jag brakes on tr6 Triumph 4
O TR6 Bleeding TR6 Brakes Triumph 2
milemarker60 TR6 My Rear Disc Brakes on the TR6/M3 Triumph 0
Brosky TR6 4 Wheel Disc Brakes for TR6 - Available? Triumph 17
delisaj TR6 TR6 Brakes are gone-- HELP!!! Triumph 7
boxofparts TR6 73 TR6 no brakes Triumph 2
N TR6 TR6 rear brakes Triumph 6
R TR6 TR6 front brakes Jack Drew Triumph 13
T TR6 Special tool needed to adjust TR6 rear brakes? Triumph 9
M TR6 newcomer needs help tr6 brakes- sorry long post Triumph 5
tr6web TR6 TR6 Rear Brakes Triumph 6
S TR6 TR6 rear brakes--quick question Triumph 3
S TR6 TR6 front brakes make loud noise Triumph 8
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
