Bullet Connectors are too large to fit Tail Lamps on BE
Jim_Gruber
SO I have nice shiny new BE Tail lamps I am trying to install. Unfortunately, the OEM connectors on the wiring harness do not fit into the little brass sleeves on the tail lamps. so what's the solution folks have used. Solder on a wire to the slip on connector and create another failure point/ Even if I put a bullet connector on there and feed it into the trunk with a single connector it's going to mean climbing into the trunk to connect things. Solutions gentlemen. The **** OEM connectors should fit the tail lamps.
I thought the rear lamps used the loose bullet sleeves?
Jim_Gruber
Jim_Gruber
If that's what you call it. Are those supposed to be solder less and just wrap bare wire around end and push on? That's got to be it. And then there is my turn signal mystery I posted an ahexp. Brake lights and running lights got to be in the 3 wire flasher unit.
Gerard
Yep, those are the correct ones. They used to be supplied with these or other lights that use these special connectors. I just bought several new brake and signal lamps for the Morris, and when I went to wire them up the other day, found they now need to be purchased separately (at least from the supplier I used).Ridiculous to buy compete lamp assemblies and have to buy the bullets separately when there's nothing else on the car that used them other than these and lamps like interior or license plate lights.
Rut
Jim,
I crawled in the boot once and fed all of the wire out of their corresponding holes and went from there. I used solder on bullets vs the slip on style and like that much better. I fed the individual wires thru the rubber boots before I soldered everything on and it was a very simple process, and solid.
Rut
Jim_Gruber
Jim_Gruber
So my plan will be to use the existing connectors that came with the tail lamps and go solder less for now but when I convert to a new wiring harness go to the loose sleeve bullets and solder on. Just trying to get Bugsy IV on the road for now and legal.Thanks Team.
nomad
The original system has been trouble free in my experience even though it looks a bit crude.
Kurt.
Jim_Gruber
Jim_Gruber
Agreed just need to keep the green off and it will usually begin working again.
Rut TR4/4A Wiring harness female bullet connectors Triumph 6
T Best way to crimp bullet connectors? Triumph 32
T Where buy bullet connectors locally [ie pick up]? Triumph 15
af3683 Soldering Bullet Connectors Triumph 11
JPSmit Bullet Connectors Spridgets 5
rlandrum Bullet Connectors Triumph 22
S Owners handbook, other manuals, bullet connectors Triumph 5
C Wanted Wanted - Ford Cortina "bullet" style gearbox Other British Classifieds 1
J Please identify these bullet mirrors - Need base and gasket Austin Healey 5
Tinkerman TR2/3/3A Bullet Mirrors on TR 3's Triumph 7
G Bullet Mirror Placement Austin Healey 24
X Royal Enfield Bullet, still in production British Motorbikes 4
RickB My Sprite dodged a bullet Spridgets 16
T Base for bullet style mirrors Triumph 16
Stinger TR4/4A TR4A Bullet Racing Style Mirrows Opinion Triumph 9
Morris Bullet mirror mounting Spridgets 10
Tinkerman Crimping Bullet Terminals Triumph 13
mountainman Bullet Wire Conecters Triumph 19
1 Yeah! Finally bit the shock absorber bullet.... Spridgets 6
I bullet mirror base part source? Triumph 1
PAUL161 Bullet Type Crimping Tool Restoration & Tools 3
1965_MGB Lucar [bullet] connector crimp tool? Restoration & Tools 14
jjbunn Bullet Mirror Triumph 7
DNK Who was looking for Bullet Pliers?? Triumph 5
IanF Need a bullet wire crimper Restoration & Tools 28
Got_All_4 TR6 TEX DOOR MIRROR VS BULLET MIRROR TR6 Triumph 22
Camshaft Bullet mirror question MG 3
Tim Tucker Rust Treatments: Por15 vs Rust Bullet Restoration & Tools 9
W Bit the bullet...... MG 17
S General Tech Electronic store for quality connectors. Triumph 9
Joe Schlosser Soldering Bullit Connectors Spridgets 8
NutmegCT battery post connectors Restoration & Tools 6
Marvin Gruber BJ8 brake connectors Austin Healey 17
K TR2/3/3A Randall....Ammeter Shunt when there are spade connectors? Triumph 2
K TR2/3/3A The round electrical connectors on the OD Gearbox Top Cover? Triumph 1
PAUL161 General MG Posi Locks, Great Connectors MG 2
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Rob Glasgow Lucas Battery Cable Helmet Connectors Austin Healey 11
mgedit TR2/3/3A Banjo Connectors TR3 Brakes Triumph 4
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
DNK Connectors Triumph 1
S TR2/3/3A tr3 unsoldered push in connectors Triumph 3
K Tail lamp wire connectors? Triumph 15
philman old mustang wiring connectors Other Cars 0
newmexTR3 TR2/3/3A TR3 Wiring harness- with or w/o connectors? Triumph 14
1965_MGB Cleaning Lucar Connectors MG 11
S electrical connectors MG 1
A TR2/3/3A TR-3 Wiring connectors Triumph 23
R Need US source for Triumph electrical connectors Restoration & Tools 7
