TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights
TuffTR250
On a TR3, is there a good way to manage all those wires and bullet connectors under the bonnet where the wires from the steering column, wires from the headlights, wires from the park/turn signal lights, and wires from the horns come together just behind the horns? It's like a tangled mess in my car, and on the drivers side they are all clustered right in the area where the dipsitck goes in and out to the sump.
In addition, on mine since I've had the grille off and the cowl off several times, I've now got strips of bright green masking tape on each wire with numbers on them to make it easier to match the wires when putting the cowl and grille back on. :smile: So it really is a sight. Please post a picture if you have a good way of cleaning up this tangle of wires. Thanks!
Regards,
Bob
TR3driver
Great Pumpkin - R.I.P
Re: Is there a good way to manage all those wires/connectors for headlights & park li
One thing that helps, a little, is if you can find the original 6-hole bullet sleeves. They effectively combine 3 2-hole sleeves, and also help organize the wires going into them.
Also, lose the green masking tape. It's actually quite easy to identify the wires with some very simple tests with a test light. I just went through that a few days ago, and the entire process of hooking up the front lamps only took about 20 minutes, including verifying the results (although not including the time it took me to figure out that the high beam indicator was burned out :smile: )
Geo Hahn
I think those wires can be formed into a fairly tight bundle. The original style notched straps help hold them altogether.
The metal straps attached to the inner wing also keep the bundles tight.
The tangle you described may also be reduced if your wires are all twisted around each other -- separating them and then reattaching one at a time may assure that the bundle is no larger than necessary.
T
TuffTR250
Thanks Randall! I have never heard of a 6 hole bullet sleeve. Where do you get those?
Thanks Geo, your's look quite neat. I like the small strap for your grounds. Mine go to various screws. A question...where do the wires come up that come out the end of the steering column? Mine come up from beside the steering column behind the horn. Another question..what is the black wire in your drivers side picture that goes up toward the top of the picture along side the radiator hose? Thanks!
Regards,
Bob
TR3driver
I'm afraid I don't know of a current source. I've been reusing originals by soaking them in silicone to soften the rubber and then replacing the contacts with the ones from new 2-hole sleeves. Sorry, I guess it wasn't a very practical suggestion.
I believe the harness from the control head is supposed to run through the metal tab on the inner fender under the apron, and then come into the junction area as Geo's photo shows.
Those ground straps are as original, I believe. Reproductions are available from TRF and British Wiring, probably Moss & VB as well.
Geo Hahn
British Wiring has a 5-hole:
https://www.britishwiring.com/5-Way-Snap-Connector-p/c335.htm
...I like the small strap for your grounds. Mine go to various screws.
That is the original way the grounds were done. I think British Wiring also has those, but I couldn't turn them up in a brief search.
As this photo shows, there are a couple of metal straps welded to the inner wing that (on mine at least) capture that bundle of wires and take up to the general confusion of wires shown in the prior pic. The same strap also captures the drivers side turn signal wires when the apron is back on:
Another question..what is the black wire in your drivers side picture that goes up toward the top of the picture along side the radiator hose?...
Shhhhh! That is my secret wire to a switch in the cockpit which grounds the 'breaker' side of the coil to disable the engine. Even if someone hot-wires the coil (which is pretty easy) it won't start until they figure out what else I've done.
I type too slow.
RC64
On the Britishwiring.com site under "Bullets & Snap Connectors" you'll find this...
Stainless Steel Grounding Clip
Product Code: C990
sp53
That is interesting. I have never seen a 6 plug connector onan original tr3.
T
TuffTR250
Geo, thanks for all the pictures and information. The switch in the cockpit sounds like a good idea.
Regards,
Bob
TR3driver
I mean 6 as in 3 on each side. If you check out the factory wiring diagrams, you'll see one of them for each headlight; which is what I've found on every TR3/A that I've owned.
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
middie Those dashed darned brake calper bolts Spridgets 6
D One Of Those Nights Triumph 4
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
pjsmetana Those darn Battery Terminals! Triumph 16
T OT - but for those of us doing body work scary Triumph 12
