TR2/3/3A those 3 white wires onto the ignition switch
sp53
Ok I hope this makes sense, I am putting those 3 white wires onto the ignition switch on an original 1958 ignition and there really is not any room for all 3 wires. So, I am thinking why not hook the one white from the ignition warning light onto white wire side of the push start. It looks to me as soon as the key is turned the post on the push start will get hot and light the light, and it should not make any difference. Then I would 2 white wires on the key and 2 whites on the push switch rather than 3 on the key and 1 on the push start.
TR3driver
Great Pumpkin - R.I.P
Yup, should work fine.
CJD
I am pretty sure I had to do something like that. I don’t remember the exact posts, but I think I followed the power to another post and tied the last white onto that other post. As long as you don’t miss and go to an always hot post it should work out fine.
Reminds me of studying aircraft schematics. The schematics always show what they call “busses”, which are common powered items. You have items on the “battery hot bus”, which is always hot but fused...or “battery direct bus”, which is always hot no matter what, so long as the battery is not dead. Then you have rt DC, Emergency DC, etc. Well, I bring this up, as I always thought of something called a “bus” as being large bar with all these wires going into it, sort of like the common “bus” in your home fuse box. I later learned airplanes don’t have any such thing! The “bus” is really just wires going from here to there to there, with no bars or any such heavy connector.
So, basically you are good moving a white wire so long as you keep it on the “battery switched” bus circuit!!?!
martx-5
Sorta like a bus driving from one stop to another.
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A source for those little drain hoses Triumph 6
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
middie Those dashed darned brake calper bolts Spridgets 6
D One Of Those Nights Triumph 4
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
pjsmetana Those darn Battery Terminals! Triumph 16
T OT - but for those of us doing body work scary Triumph 12
deadair TR2/3/3A For those who's TR3s are up on blocks Triumph 14
