One Of Those Nights
DougF
Took the TR6 over to a friend's house to fix my brake lights and help him with his new TR6. After several hours of brake lights working/not working/working with tail lights/not working with tail lights and inconsistant readings with the multimeter, it was decided that there was a short. But where?
The right lamp was working consistantly, but the left one wasn't, so we decided it wasn't in the rear end.
My friend pulled up my drivers side carpet to chase the wire back, and found a 3/4" puncture hole in my floor. I hit something on the road last year and thought I must have damaged the rocker panel but got the floor instead. The puncture caused the cut metal to bend around pinning the harness under it and cutting the insulation. What are the chances?
Finally, at 1:30 AM we started tinkering with his wipers. When I got in the car to leave, I had no brakes. No fluid loss from the reservoir. Hopefully, they just need bled...will find out in the morning.
Platinum
Woof. Total sympathy, Doug. Though it was many years ago, as I read of your deviant electron behavior, this experience immediately came to mind: My first MGB rebuild/refurb, it needed floor pans but we had no money for "official" ones so fabricated 'em. Body work all done, car painted, it came time to reconnect all the lights, etc. Testing tail-lights and signals the thing seemed posessed. Right indicator on, left would blink. Right one on, the left brakelight would blink... brake pedal would activate the wrong (t-sig) bulbs. First came suspicion of a bad ground. Nope. A few hours of tail chasing with a meter and we were befuddled. Then we followed the harness under the car... I had drilled/pop-riveted the replacement flooring, putting a pop-rivet into the harness! Dad had a great laugh over that. I was just embarrassed.
Lesson learned, 1970. :shocked:
DougF
It's a master cylinder. Ordered a rebuild kit from TRF and will pick it up on Monday.
Kicking around buying a new rear harness. Still the original. Replaced the front harness last summer.
Brosky
Doug, make sure there was no bleed back into the booster that can hurt the diaphragm in that unit.
Z one of those nights Spridgets 9
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
middie Those dashed darned brake calper bolts Spridgets 6
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
pjsmetana Those darn Battery Terminals! Triumph 16
T OT - but for those of us doing body work scary Triumph 12
