A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing
Jim_Gruber
I've been dreading installing rear brake circlips to the point where I ordered a CirClip Install tool from Spridget Mania. Well it was not in the mailbox today so I said WTH let me try it anyway without the fancy tool. Took my Wheel Cylinder to True Value and matched up the CirClip that comes with the Wheel Cylinder to one a little thinner but still 5/8" ID. Same as the bastard clip that came with the wheel cylinder. I made a gasket out of gasket material. That $5 leather punch kit from Michaels or Hobby Lobby came in handy once again. Gasket provided additional space taken up so the Wheel Cylinder fit just right. Cleaned out the hole for the roll pin, and turned upside down on my workbench with wheel cylinder and gasket in place pushed up against the base of my bench vise. I added a small piece of scrap wood to make the assembly level. Then with my BF Screw driver pushing exactly in the center of the E and another screwdriver holding things down I started pushing. Lo and behold the E Clip Spread, rode right into the slots on the wheel cylinder and seated itself with all three tangs in place and aligned correctly and securely in the grooves. Voila. I learned that I needed to trim a hair off of the back of the Circlip so I did not hold the hub proud and things were sitting flat
Horray a victory over those bastards and I was really feeling chuffed. However as I went to tighten down the hubs I discovered that on one side the back of the wheel studs are rubbing on the Wheel Cylinder. WTH????? So I took a little edge off of the back of the wheel stud and that seemed to help but WTH is it rubbing. Not rubbing on the other side. Could I have a bent backing plate. That's about all I can figure. Between relieving the back of the wheel cylinder a smidgen and the same on the back of the wheel hub I can probably fix. But does anyone have a right side later backing plate kicking around their garage. Just in case the issue is the backing plate. Thanks.
got it in o
Joe Schlosser
Is backing plate firmly up against the axle.
Clearance between the cylinder rubber boot and studs is very close.
Anything pushing the plate or the cylinder out board may cause the studs to rub on the hub.
Where did you add this "gasket" you made. Between the cylinder and the plate??
Jim_Gruber
Jim_Gruber
Yes between the gasket and plate. Without the gasket wheel Cylinder moves around. Since the Spridgetmania video on rebuilding the rear end discusses use of gasket I made one. Helps to stabilize the wheel cylinder. Much tighter fit. I've got a right rear backing plate being shipped to me on Monday.
we are backing plate coming from
Jim_Gruber
Jim_Gruber
Found a source for a backing plate. Will see if that fixes the issue.
John_Mc Victory by Design/ Jaguar Triumph 5
aeronca65t Victory Lane magazine-Oct-2011 Racing 5
Brosky Victory over the "evil door glass gremlins" Triumph 2
regularman Victory! Spridgets 25
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
A VICTORY is mine!!! Spridgets 2
78Z Victory by Design - Lotus - Dec 19th Lotus 3
I Victory Edition? Triumph 0
G Victory By Design : Jaguar!! Jaguar 6
KVH General Tech Rebuild Report Triumph 6
nichola TR6 TR6 two year build report Triumph 1
Sherlock A report from hinterland (and French cars) Spotted 4
jlaird MGB Would report MG 1
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
T TR2/3/3A TRip report 2019 Triumph 4
Mickey Richaud General MG Road Trip Report MG 6
KVH TR4/4A Report on Pertronix Triumph 6
Pythias 1275 Transplant --- Final Report Spridgets 4
Michael Oritt Report from Watkins Glen Racing 11
Moseso Technical Report: Bronze Spring Bushes Triumph 26
Mickey Richaud British V8 Report? MG 9
Tinkerman Progress Report Triumph 4
Tinkerman TR2/3/3A Progress Report 60TR3A Triumph 6
Mickey Richaud Mileage Report MG 8
jlaird I would like to report Spridgets 3
angelfj1 Progress Report Triumph 12
Morris All British Car Day Report Spridgets 9
JPSmit MG2010 report Spridgets 6
drooartz 1000 mile report Spridgets 15
TR4nut TR2/3/3A Very brief status report and question on TR3A Triumph 26
jlaird I would like to report Spridgets 4
S Heritage Report for my 56 MkI Saloon Jaguar 4
Cottontop Healeys Return to Bonneville - Trip Report Austin Healey 4
JPSmit British Car Day Report Spridgets 8
3798j Wedge TR8 Drive Report Triumph 1
Ohiobugeye Progress Report Spridgets 1
Westfield_XI Westfield 11 status report April 2009 Lotus 1
mrv8q Today's weather report... Triumph 68
jlaird Status report-garage Spridgets 8
jlaird Tony, status report Spridgets 3
ronzet Progress Report '66 Rebuild.. MG 48
NutmegCT ScanGauge report Restoration & Tools 6
Moseso Advanced Ditributors report Triumph 10
eejay56 Spitfire 200$ Spitty report Triumph 10
Lin BT7 restoration progress report Austin Healey 6
regularman A small bit of progress to report. Spridgets 3
N TR6 Progress report #2 on white TR6 Triumph 9
N TR6 Progress report on White TR6 Triumph 10
N Brosky requested Progress Report Triumph 2
prb51 TR2/3/3A TR3 front suspension report Triumph 6
