Check those splines!
Saw a prime example of spline failure yesterday...
One of the registrants here at BritishV8 had the splines on a front hub fail.
I was right behind him; saw something shiny bounce on the road and go off into the side brush. Thought he hit a beer can....but just a couple of seconds later, his right front wheel came flying off.
Fortunately, we were only going about 30mph (opposed to the 70mph we had just been travelling).
We found both the wheel and the knock-off (that was a stroke of luck!) and got the car reassembled.
Minor damage to the rotor and dust shield...
But....
In less than 1/4 mile, the knock off loosened again.
The splines on the hub are shot; the splines inside the wheel are shot.
He was VERY lucky.
Check those splines on a regular basis.
New hubs = new wheels in most cases.
FWIW....
Mickey Richaud
Thanks, Rick - one more item that's often overlooked/taken for granted.
Other than that, hope all are enjoying the event!
Mickey
drooartz
I'll admit that this is a big reason why I didn't want wire wheels on my B, no matter how cool they look. Yikes!
MikeP
Besides that is the possibility of them failing under emergency stopp conditions leaving you with less than 4 wheel brakes. And if it happens on a front, the car will jerk towards the still functioning side.
I keep several hubs with varying degrees of wear in my garage to show people what worn out looks and feels like.
PAUL161
I was very fortunate when I bought my 55 TF, as the hub splines are in very good condition, wheels included. If needed, expensive to replace, but could be life saving! Can't put a price on that! PJ
rick_ingram
I would consider it a Public Service Announcement if you were to take some pictures and post them!
I **think** Moss has a picture of some badly worn splines that I've seen someplace.
PAUL161
Found these,
Moderately bad spline.
Very bad spline.
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
drooartz General Tech Check those brake hoses! MG 11
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
sundown TR6 Door check strap Triumph 3
